Thread Closed
equilibrium and gravity on a uniform beam
Share Thread Thread Tools
Apr6-09, 01:51 PM   #1
a uniform beam of length 12.0 m is supported by a horizontal cable and a hinge at angle θ = 70° with the vertical. The tension in the cable is 500 N. Find the gravitational force on the beam in unit vector notation and the force on the beam from the hinge in unit vector notation.
2. Relevant equations
force from gravity = mg
vertical force on beam from hinge = mg
Horizontal component of gravity = 0
horizontal component of force of hinge on beam = 500N
3. The attempt at a solution I know that the horizontal force on the beam has to be in equilibrium with the tension of the cable.
T = .5(horizontal distance) ( gravity) (mass)/ vertical distance
500 = (.5(9.8)(12sin70)m)/(12cos70)
m= 37.13
mg = 363 but its wrong =\
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr6-09, 06:24 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Hi alexandertg6! Welcome to PF!
Quote by alexandertg6 View Post
hmm … you've taken moments about the hinge
but what's 12sin70º ?
Thread Closed
Thread Tools
Similar Threads for: equilibrium and gravity on a uniform beam
Thread Forum Replies
Gravitational torque on a uniform beam: Cavendish experiment (LAB) Advanced Physics Homework 2
Torque on a uniform beam Introductory Physics Homework 2
Deflection of a beam with non-uniform section Mechanical Engineering 5
beam with uniform loading supported at 4 corners General Engineering 4
Static Equilibrium Beam/supports? Introductory Physics Homework 12
