Calculating Spectrum Width of White Light on a Diffraction Grating
  • Context: Undergrad
  • Thread starter Thread starter Velocity
    Light White light
The discussion focuses on calculating the spectrum width of white light using a diffraction grating with 3000 lines/cm. The relevant formula is the diffraction grating equation, nλ = d sin θ, where n is the order of the spectrum, λ is the wavelength, and d is the grating spacing. For this scenario, the longest wavelength (750 nm) corresponds to the second order (n=2) and the shortest wavelength (400 nm) corresponds to the third order (n=3). By applying trigonometric principles and the distance of 100 cm from the grating to the screen, the width of the spectrum can be determined.
  • Understanding of the diffraction grating equation
  • Basic trigonometry for calculating angles
  • Knowledge of wavelength measurements in nanometers
  • Familiarity with the concept of antinodes in wave physics
  • Study the diffraction grating equation in detail
  • Learn how to calculate angles using trigonometric functions
  • Explore the concept of spectrum width in optics
  • Investigate the effects of different grating densities on diffraction patterns
Students and educators in physics, optical engineers, and anyone interested in the principles of light diffraction and spectrum analysis.
Velocity
This question really has me stumped..i would appreciate it if anyone could help me out:smile:
White light containing wavelengths of 400nm to 750 nm is shone normally onto a diffraction grating of 3000 lines/cm. Calculate the width of the spectrum that appears as the second antinode on a screen that is 100 cm away.
Is there a specific formula I can use to solve the question? If so then please help.. thanks
Science news on Phys.org
Yes, use the diffractin grating equation.
n lamda = d sin theta
Rearrange the terms, solve for theta for two cases -- the longest wavelength at the n=2-mode and the shortest wavelength at the n=3-mode. Use this information with the distance between the grating and the screen to solve the problem -- just a little trigonometry.
eNtRopY
  • · Replies 207 ·
16K
  • · Replies 17 ·
