Thread Closed
Submarine Fires Torpedo, Submarine's Recoil?
Share Thread Thread Tools
Apr9-09, 09:24 PM   #1
A submarine of mass 2.5 x 10^6 kg and initially at rest fires a torpedo of mass 260 kg. The torpedo has an initial speed of 100.4 m/s. What is the initial recoil speed of the submarine? Neglect the drag force of the water.
2. Relevant equations
m1v1=-m2v2
3. The attempt at a solution
mass one = 2.5x10^6 (submarine)
velocity one = 0 (sub isnt moving)
mass two = 260 (torpedo)
velocity two = 100.4 (torpedo)
How can I find the recoil? I thought maybe it'd just be velocity one (instead of zero solve for x)
v1 = (260*100.4)/2.5x10^6 = -0.01 m/s
But that's wrong...
what am i missing?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Apr9-09, 09:34 PM   #2
I think you have the right idea, but you need to do it like this:
m1v1 (of sub) + m1v1 (of torpedo) = m2v2 (of sub) + m2v2 (of torpedo)
and since initial velocity of the sub is 0
I think this is right, hope this helps!
Apr9-09, 09:45 PM   #3
Recognitions:
Homework Helper Homework Help
Quote by Schoomy View Post
m1v1=-m2v2
But that's wrong...
what am i missing?
They are asking for speed and not velocity. So I would expect they are not looking for a negative number.
Apr9-09, 11:57 PM   #4
Yeah, but if we have:
doesnt m1v1 (torpedo) = m2v2 (torpedo) ? thus you'd just subtract one from the other, giving zero, resulting in:
0 = m2v2 (of sub)
Result would be undefined. What am I missing?
Apr10-09, 12:22 AM   #5
Initially in the problem, before the torpedo is fired, what is the momentum of the system? The total momentum after the torpedo is fired must be the same.
Apr10-09, 12:24 AM   #6
so for m1v1 (torpedo) is the initial mass the sub plus the torpedo?
Not sure I follow, can you be more specific?
Apr10-09, 12:26 AM   #7
Yes it would be. However, I think you're missing the point. The sub initially has no velocity, and the torpedo initially has no velocity. Therefore, what is the initial momentum of the system?
Apr10-09, 12:29 AM   #8
zero...
Apr10-09, 12:31 AM   #9
That's correct. If the initial momentum of the system is zero, then because of the conservation of momentum, the final momentum of the system must be zero. Does that help you at all?
Apr10-09, 12:35 AM   #10
I still don't get it...
Initial Momentum of System (aka zero) = m_sub*v_sub + m_torpedo*v_torpedo
Rearrange:
- m_sub*v_sub = m_torpedo*v_torpedo
Resulting in:
- (2500000)(recoil) = (260)(100.4)
-Recoil = ((260)(100.4))/2500000 = -0.0104416, which isn't accepted answer...
Apr10-09, 12:39 AM   #11
Do you happen to know what the correct answer is? How do you know it's not the accepted answer?
Apr10-09, 12:41 AM   #12
Our assignments are administered online via webassign.com.
It says -0.01 is wrong...
Apr10-09, 12:44 AM   #13
Have you tried it without the negative sign? And/or with more or less significant figures? I don't know why that answer would be wrong. However, if you're required to have the correct number of significant figures based on the problem, your answer should be 0.010.
I hope one of these solutions works for you
Apr10-09, 12:46 AM   #14
Odd...
The program allows for a 2% error and I've tried with any number of significant figures/variations (this is just practice, so I can try as many times as I want with no penalty)
Just frustrating because I understand all other recoil problems except this one...
Apr10-09, 12:47 AM   #15
I have a similar problem (somewhat different concept...vertical height acheived).
http://www.physicsforums.com/showthr...=1#post2154921
We can't seem to figure it out...care to take a look for me?
Apr10-09, 12:53 AM   #16
Recognitions:
And do they say + .01 is incorrect?
Apr10-09, 12:56 AM   #17
Yes,
These are wrong:
-0.01
0.01
0.010, etc
0.01044etcetc
Very odd
Thread Closed
Thread Tools
Similar Threads for: Submarine Fires Torpedo, Submarine's Recoil?
Thread Forum Replies
Kursk was shot down by US torpedo. Current Events 18
Submarine's maximum safe depth Introductory Physics Homework 3
Problem of photon torpedo Advanced Physics Homework 4
submarine and torpedo Introductory Physics Homework 2
U-Boat Torpedo Firing Solution Problem General Math 2
