| Thread Closed |
RC Circuit question |
Share Thread | Thread Tools |
| Apr10-09, 07:49 PM | #1 |
RC Circuit question
All capacitors of the open circuit in fig. 3 are discharged when, at time t=0, the switch S1 is closed. At some point later, at time t = t1, the switchS2 is also closed. What is the charge Q1(t2) on the capacitor C1 at time t = t2 > t1? ![]() 2. Relevant equations Charging capacitor: [tex]q = C\epsilon(1 - e^{\frac{-t}{RC}})[/tex] Discharging capacitor: [tex]q = {Q_0}e^{\frac{-t}{RC}}[/tex] 3. The attempt at a solution Ok, I said that when S1 was closed at t1, the resistors arein parallel, giving q at t1 equal to: [tex]{C_1}\epsilon(1 - e^{\frac{-t}{(R_1+R_2+R_3+R_4)(C_1+C_2)}})[/tex] Now the thing I need help with is determining the equivalent resistance when S2 is closed. The best I can think of is that only R2 and R4 are acting. That would give: [tex]{C_1}\epsilon(1 - e^{\frac{-t}{(R_1+R_2+R_3+R_4)(C_1+C_2)}})e^{\frac{-t}{(R_2+R_4)(C_1+C_2)}}[/tex] Can anyone help me determine the resistance in this last step? I'm out of ideas. Thanks! |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Apr10-09, 08:17 PM | #2 |
Recognitions:
When S2 is closed, you are creating a short circuit. Hence no charging will take place. But initially charged capacitors will discharge through R3 and R4.
| Apr10-09, 08:34 PM | #3 |
So would the time constant for the discharging period be (R3+R4)(C1+C2)?
| Apr10-09, 08:39 PM | #4 |
Recognitions:
RC Circuit question
Yes.
| Apr10-09, 08:53 PM | #5 |
Ok, that would give:
[tex]{C_1}\epsilon(1 - e^{\frac{-t}{(R_1+R_2+R_3+R_4)(C_1+C_2)}})e^{\frac{-t}{(R_3+R_4)(C_1+C_2)}}[/tex] as the answer then. Thanks for your help. |
| Apr10-09, 09:05 PM | #6 |
Recognitions:
| Apr10-09, 09:08 PM | #7 |
I thought that both capacitors were used in RC, the time constant, and that C1 was used by itself only when dealing with Qf, or C*epsilon.
Basically, I was fairly certain that the time constant is the same regardless of which capacitor you are looking at. Is this not the case? |
| Apr10-09, 10:43 PM | #8 |
Recognitions:
Across C1 and C2 potential difference is the same. During discharge, time constant for C1 is C1(R3+R4). At the instant of discharge charges on C1 and C2 are not the same.
| Apr10-09, 10:49 PM | #9 |
Ok, I see what you're saying, and that sounds right.
Thanks again for the help. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: RC Circuit question
| Experts please: DC CIRCUIT (PARALLEL-SERIES CIRCUIT) QUESTION | Introductory Physics Homework | 3 | ||
| Short Circuit, and open circuit question | Engineering, Comp Sci, & Technology Homework | 1 | ||
| LC circuit question | Classical Physics | 1 | ||
| RC Circuit/Question | Engineering, Comp Sci, & Technology Homework | 3 | ||
| DC circuit question.. | Introductory Physics Homework | 2 | ||
