Luminous Blob
- 50
I am trying to find the power series solution of
[tex]y' = x^2y[/tex]
but don't know how to arrive at the answer of [tex]y = a_0exp(x^3/3)[/tex]. [I know that it's an easily solved separable equation, I'm just trying to figure out how to find the power series solution]
My solution so far:
Assume
[tex]y = \sum_{n=0}^\infty a_nx^n[/tex]
then
[tex]y' = \sum_{n=1}^\infty na_nx^{n-1}[/tex]
giving:
[tex]\sum_{n=1}^\infty na_nx^{n-1} = x^2 \sum_{n=0}^\infty a_nx^n[/tex]
[tex]\sum_{n=1}^\infty na_nx^{n-1} = \sum_{n=0}^\infty a_nx^{n+2}[/tex]
changing the index for the LHS to give [tex]x^n[/tex]
[tex]\sum_{n=0}^\infty (n + 1)a_{n + 1}x^n[/tex]
changing the index for the RHS to give [tex]x^n[/tex]:
[tex]\sum_{n=2}^\infty a_{n - 2}x^{n}[/tex]
Then taking the first two terms out of the LHS sum, so that both sums start from the same point:
[tex]a_1 + 2a_2x + \sum_{n=2}^\infty (n + 1)a_{n + 1}x^n = \sum_{n=2}^\infty a_{n - 2}x^{n}[/tex]
I don't know what to do after this (I'm not entirely sure if what I've done so far is right, either).
If the y term in the initial equation didn't have the [tex]x^2[/tex] in front of it, it would be easy to equate the coefficients of [tex]x^n[/tex] to get the recursion formula. But having the terms [tex]a_1[/tex] and [tex]2a_2x[/tex] in front of the sum on the LHS throws me - can anyone explain clearly to me the correct steps required to solve the problem?
My solution so far:
Assume
then
giving:
