Does this integral converge or diverge?
  • Thread starter Thread starter Dell
    Integral
The integral \(\int \frac{dx}{\ln(x)}\) from 0 to 1 diverges due to undefined behavior at both limits. The discussion highlights the use of substitution \(t = \ln(x)\) and integration by parts, which proved ineffective for this integral. Instead, the user successfully identified bounding integrals: \(\int \frac{dx}{\sqrt{x}}\) from 0 to 0.4 converges and is greater than \(\int \frac{dx}{|\ln(x)|}\) from 0 to 0.4, while \(\int \frac{1}{x} dx\) from 0.6 to 1 diverges and is less than \(\int \frac{dx}{|\ln(x)|}\) from 0.6 to 1. Thus, the conclusion is that the original integral diverges overall.
  • Understanding of improper integrals
  • Familiarity with logarithmic functions and their properties
  • Knowledge of integration techniques, including substitution and integration by parts
  • Concept of bounding integrals for convergence tests
  • Study the properties of improper integrals in detail
  • Learn about convergence tests for integrals, including the comparison test
  • Explore advanced integration techniques, particularly substitution methods
  • Investigate the behavior of logarithmic functions near their limits
Mathematics students, calculus instructors, and anyone studying improper integrals and convergence in mathematical analysis.
Dell
the given integral is:
[tex]\int[/tex][tex]\frac{dx}{ln(x)}[/tex] (from 0 to 1)
now i have a problem at both ends of the integral, because i have ln(0) is undefinde and ln(1) is 0 and 1/0 is undefined, so i can integrate from 0 to 0.5 and 0.5 to 1, but i tried to integrate this and just couldnt, i tried substitution
t=ln(x)
x=et
dt=dx/x
and then tried integration in parts but this just didnt work,
so then i thought maybe i need to find a similar function which i know more about or can easily find more about, but again i have problems at both limits, so i think i need 2 separate functions, since i know that 1/ln(x) is negative in the limits 0-1, i will take the abs value of 1/ln(x) and look for positive functions...
i am looking for an integral that is either
*bigger than my original integral and converges
*smaller than my original integral and diverges
what i found was
[tex]\int[/tex]dx/[tex]\sqrt{x}[/tex] (from 0 to 0.4) which converges and is bigger than [tex]\int[/tex]dx/|ln(x)| (from 0 to 0.4 )
and my second integral is [tex]\int[/tex]1/x (from 0.6 to 1) which diverges and is smaller than [tex]\int[/tex]dx/|ln(x)| (from 0.6 to 1 )
therefore i know that the integral [tex]\int[/tex][tex]\frac{dx}{ln(x)}[/tex] (from 0 to 1) diverges near 1, and converges near 0, so all in all it diverges.
is this okay? is it alright that i didnt take into account the area between 0.4 and 0.6 since the function is constant there anyway??
can you see any better way to solve this??
I came to a similar conclusion using your first substitution t=ln|x|. I found this easier to visualize. The lower limit of zero transforms to negative infinity and it is clear that the integral of exp(t)/t converges at negative infinity. However the upper limit of 1 transforms to zero and it is clear that the integral of exp(t)/t diverges at zero, since the numerator goes to unity and the denominator is a divergent 1/t form.
  • · Replies 34 ·
  • · Replies 54 ·
19K
