Rotating square coil in constant magnetic field
The discussion focuses on calculating the torque of a rotating square coil in a uniform magnetic field. The coil has an area A and rotates around the y-axis with an angular speed ω. The correct expression for torque is established as T = A²B²N²ω sin(ωt)/R, derived from the relationship T = |m × B| where m = NIA. The confusion arises from the application of EMF, specifically the equation EMF = -N(dΦ/dt), which is crucial for determining the current I and subsequently the torque.
  • Understanding of electromagnetic induction principles
  • Familiarity with torque calculations in physics
  • Knowledge of Faraday's law of electromagnetic induction
  • Basic concepts of magnetic fields and their interactions with current-carrying conductors
  • Study the derivation of Faraday's law of electromagnetic induction
  • Learn about the relationship between current, voltage, and resistance in circuits
  • Explore torque calculations for different geometries of coils in magnetic fields
  • Investigate the effects of varying magnetic field strength on induced EMF and torque
Students of physics, particularly those studying electromagnetism, electrical engineers, and anyone involved in designing or analyzing electromagnetic systems.
snufkin
There is one square coil of area A that rotates with speed [tex]\omega[/tex] around axis y. The magnetic field is uniform and points to the z direction. Show that the torque is [tex]\frac{A^2B^2N^2\omega sin\omega t}{R}[/tex].
[tex]T = |\underline{m} \times \underline{B}|[/tex]
[tex]\underline{m} = N I A[/tex]
Thus [tex]T = NIABcos(\omega t)[/tex]
Unsure about these:
[tex]EMF = NIR[/tex]
[tex]EMF = - N\frac{d \Phi}{d t}[/tex]
Now I have read many similar questions on this forums, and I think I am close to fully understand the problem itself, but there is a piece missing, and I don't see from my initial equations where I am going wrong.
I calculate I via the EMF, substitute it into T. But with this I end up with one N, whereas the supposed solution that I need to prove in the exercise is [tex]T = \frac{A^2B^2\omega sin^2\omega t}{R}[/tex].
I am assuming one of the initial equations wrong, I suspect the EMF section, because I not understand it. Any help would be appreciated.
Thinking of V that is probably wrong, the number of loops has nothing to do with the potential, so [tex]V = IR[/tex].
So EMF is [tex]-N \cdot \frac{d \Phi}{d t}[/tex] because we take [tex]\Phi[/tex] at each loop, and just sum those up. I am wondering now why can we actually do that, since in a different alignment the flux in each loop must be different.
The flux is the same for each loop, so yes EMF = -N dΦ/dt
  • · Replies 17 ·
