Highest force is at ZERO speed ?
  • Context: Undergrad
  • Thread starter Thread starter waynexk8
    Force Speed Zero
The discussion centers on the concept that the highest force exerted occurs at zero speed, particularly in the context of weightlifting. It is established that the maximal voluntary isometric contraction force is slightly greater than the force produced during a one-repetition maximum (1RM) lift due to the dynamics of static versus kinetic friction. The mechanics of force, defined as force = mass x acceleration, indicate that overcoming static friction requires more force than maintaining motion against kinetic friction. Therefore, while an athlete may lift a maximum weight of 200kg, the force exerted on a non-moving object can exceed this under isometric conditions.
  • Understanding of basic physics principles, specifically Newton's laws of motion.
  • Familiarity with concepts of static and kinetic friction.
  • Knowledge of weightlifting terminology, including one-repetition maximum (1RM) and maximal voluntary isometric contraction.
  • Basic understanding of force calculations (force = mass x acceleration).
  • Research the mechanics of static versus kinetic friction in detail.
  • Explore the implications of isometric exercises on strength training.
  • Study the effects of force production in weightlifting and how it relates to injury prevention.
  • Learn about the use of force plates in measuring strength and force output during lifts.
Weightlifters, strength coaches, sports scientists, and anyone interested in the biomechanics of force production in resistance training.
waynexk8
highest force is at ZERO speed ?
Hi all,
I say you can use more force on a non movable object than an object that is you’re RM, which is the maximum weight you can lift one time 1RM. Who is right, and is there an equation to prove this.
The "highest force" as I suggested is at ZERO speed. That is simply indicative that if you allow something to move, the amount of force you can generate against it will decline, or you will have to attempt to accelerate it (if it has mass that is).
The 1RM of a movement will produce slightly less force than the maximal voluntary isometric contraction, as the 1RM is dynamic rather than static or non movable.
Example, an athlete's max squat 200kg, at 201kg, the athlete would not be able to move the bar; however, if he applied max effort the maximal voluntary isometric contraction force would be slightly greater than the force produced during the successful 1RM lift.
Wayne
Hi Wayne,
Good question.
Strictly speaking from a mechanics approach the definition of force is: force=mass x acceleration
The force obtained can then be multiplied by a coefficient of friction. When an object is at rest it has a static friction, when it is in motion, it has a kinetic friction (which is generally smaller than static friction). In other words, as long as the athlete does not overcome the (force of static friction + force), the weight will not move. Once the weight is in motion, the force of kinetic friction(instead of static friction) is added to the force and the weight will move more freely. So yes, as long as the weight is not in motion, the force required to move it is greater.
However, if you calculate work, lifting the weight as far as you can will prove to be far more beneficial, as you will multiply the force by the distance. Anyways this is pretty simplified but I hope it helps. Train safely!
Hi and thx,
Novolks said:
Hi Wayne,
Good question.
Strictly speaking from a mechanics approach the definition of force is: force=mass x acceleration The force obtained can then be multiplied by a coefficient of friction. When an object is at rest it has a static friction, when it is in motion, it has a kinetic friction (which is generally smaller than static friction). In other words, as long as the athlete does not overcome the (force of static friction + force), the weight will not move. Once the weight is in motion, the force of kinetic friction(instead of static friction) is added to the force and the weight will move more freely. So yes, as long as the weight is not in motion, the force required to move it is greater.
See what you are saying there, it would take 200.5kg to move the weight, but only 200kg to keep it moving.
Could we forget about multiplying the force by the distance for now.
However, if my max lift was 200kg on a dynamic moving object, but if I applied my max force/strength on a non moving static object, in my opinion my max force/strength would be more, not much more, but if we were on a force place I could register say ? 3kg more than I did on the dynamic moving object, would you agree ?
Its sort of the same as if I crashed into a car with my car, there would be a lot of damage, however if the car that I crashed into was bolted down, there would be more damage to both cars
Hope I am explaining right.
Wayne
  • · Replies 39 ·
10K
  • · Replies 29 ·
10K
12K
  • · Replies 16 ·
18K
