The Euler formula how was it developed?
The discussion centers around the development of Euler's formula, specifically the identity e^{i\theta} = cos(\theta) + i sin(\theta). Participants explore the historical context, mathematical proofs, and the role of complex logarithms in understanding this identity.
  • One participant expresses confusion about how complex logarithms relate to Euler's formula and the choice of e as a base in the expression w = bz.
  • Another participant suggests that natural logarithms were likely not involved in Euler's original discovery of the identity, proposing that power series provide a straightforward proof.
  • A different viewpoint emphasizes the historical perspective, mentioning the differential equation defining e^z and how it relates to the unit circle in the complex plane.
  • One participant presents a proof involving the integral of dz/z and the relationship between the logarithm of a complex number and the angle θ, leading to the conclusion that e^{i\theta} equals cos(θ) + i sin(θ).
  • Another participant references Euler's work, suggesting that he provided a proof using power series in his text "Introductio in analysin infinitorum."
Participants do not reach a consensus on the historical development of Euler's formula or the specific role of complex logarithms. Multiple competing views and interpretations of the proof methods remain present in the discussion.
Some participants note the ambiguity in the relationship between complex logarithms and Euler's formula, as well as the dependence on definitions of logarithms in the complex plane. The discussion also highlights unresolved aspects of the historical context of Euler's work.
Skynt
I'm reading a book called The Road to Reality by Roger Penrose, and I'm on the chapter for complex logarithms. What I don't understand is how the identity e[tex]\theta i[/tex] = cos [tex]\theta[/tex] + i sin [tex]\theta[/tex] is found through the use of complex logarithms. I also don't understand how if w = ez, z = log r + i[tex]\theta[/tex] if w is in [r, [tex]\theta[/tex]] form.
Basically, he explains in this book that e was chosen as a base in the general form w = bz because it reduces the ambiguity of bz.
I guess I'm just not seeing how the complex logarithm comes into play for the Euler formula being developed.
EDIT: Sorry about the format of the post, I was just trying latex. I hope someone can clear this up for me, because I feel it's something obvious I'm not understanding.
Off hand I don't know how Euler first discovered his identity, but I don't think natural logs were involved. However, the easiest way to prove the identity is to expand both sides into power series and see that these series are identical.
First you have to think about what it means to write [itex]e^{z}[/itex] for complex z. One way is via power series as already mentioned. Another is in terms if the differential equation [itex]\frac{d}{dz}e^z = e^z[/itex], e0=1 (ez is its own derivative), which I imagine is how the concept arose historically.
If you express ei z = u(z) + iv(z) for real u and v and use the differential equation definition, then simple computation will show that ei z has length 1, its derivative has length 1, and [itex](\frac{d}{dx}e^x)(0)=i[/itex], so the curve z->ei z must trace out the unit circle in the u-v plane counterclockwise at unit-speed. (sin,cosine) also traces out the unit circle at unit speed, so Euler's formula follows.
Maybe this is the proof you mean (I saw this somewhere on mathworld I think)?
let [tex]z=\cos{\theta}+i\sin{\theta}[/tex]
then [tex]\text{d}z = -\sin{\theta} + i\cos{\theta} \, \text{d}\theta= i(\cos{\theta}+i\sin{\theta}) \, \text{d}\theta[/tex]
The integral
[tex]\int{\frac{\text{d}z}{z}}[/tex]
can be evaluated in two ways. First you can say
[tex]\int{\frac{\text{d}z}{z}} = \log{z} = \log{(\cos{\theta}+i\sin{\theta})}[/tex]
On the other hand you can substitute in dz and z to get
[tex]\int{\frac{i(\cos{\theta}+i\sin{\theta})}{\cos{\theta}+i\sin{\theta}}} \, \text{d}\theta =\int{i \, \text{d}\theta[/tex]
so
[tex]\log{(\cos{\theta}+i\sin{\theta})} = i\theta[/tex]
[tex]e^{i\theta} = \cos{\theta} + i\sin{\theta}[/tex]
I believe I have seen the page of Euler's introductio in analysin infinitorum where he gives the proof in terms of power series.
  • · Replies 18 ·
  • · Replies 18 ·
