Radius of Curvature Derivation for Bending of Beam w/Overhangs
  • Thread starter Thread starter Freyster98
    Curvature Radius
The discussion revolves around deriving an expression for the radius of curvature of a simply supported beam with overhangs, focusing on geometric methods and the application of the Pythagorean theorem. Participants explore different approaches to this derivation as part of a lab assignment.
  • Homework-related
  • One participant presents a derivation using the Pythagorean theorem, leading to an expression for the radius of curvature.
  • Another participant confirms that using the Pythagorean theorem is acceptable but suggests that a factor of 2 may have been overlooked in the derivation.
  • A different method involving similar triangles is proposed as potentially quicker and less prone to error, though one participant expresses confusion about this approach.
  • One participant admits that their attempt using similar triangles resulted in an expression for the diameter rather than the radius, indicating a misunderstanding in the application of the method.
Participants do not reach a consensus on the best method for deriving the radius of curvature, with multiple approaches discussed and some uncertainty expressed regarding the similar triangles method.
There are indications of missing assumptions or steps in the derivations, particularly regarding the factor of 2 mentioned by participants. The discussion also highlights the potential for confusion between diameter and radius in the context of similar triangles.
Freyster98
Derive an expression geometrically for the radius of curvature of the following beam. This is part of a lab assignment for the bending of a simply supported beam with overhangs.
** I did this crappy diagram with AutoCAD, so I couldn't ( or didn't know how to ) include greek letters. Let's let r= [tex]\rho[/tex], and d= [tex]\delta[/tex] for my derivation.
a2+b2=c2
I just used the pythagorean theorem to solve for [tex]\rho[/tex].
Starting with: [tex]\rho[/tex]2= ([tex]\rho[/tex]-[tex]\delta[/tex])2+(L/2)2.
Factoring out ([tex]\rho[/tex]-[tex]\delta[/tex])2 , solving for [tex]\rho[/tex] and simplifying , I end up with the following expression:
[tex]\rho[/tex]=([tex]\delta[/tex]/2)+(L2/8[tex]\delta[/tex])I guess I have this question...is this the proper way to derive the radius of curvature geometrically? Is it ok to do it this way?
Hi Freyster98! :smile:
(have a rho: ρ and a delta: δ :wink:)
Yes, Pythagoras is fine :smile: (though you seem to have lost a factor of 2 somewhere :confused:).
But there is quicker method (with less likelihood of a mistake):
Hint: similar triangles :wink:
I ran through it a few times...I don't see where I'm losing a factor of 2.
sorry … my similar triangles method (have you tried that yet?) gave me the diameter, not the radius :rolleyes:
so i got an extra 2 :redface:
Ok, thanks. No, I haven't tried the similar triangles because, well, I don't get it :rolleyes:
ok … the triangle with sides d and L/2 is similar to the triangle with sides L/2 and … ? :smile:
  • · Replies 20 ·
