Rolling disk with point mass on edge
The problem involves a point mass attached to the rim of a solid disk, which rolls back and forth without slipping after being displaced from its equilibrium position. The objective is to derive the period of this motion, considering the dynamics of the system.
  • Participants discuss the moment of inertia of the system and the application of the parallel axis theorem. There is uncertainty about how to effectively set up the equations of motion and whether conservation of energy is a suitable approach. Some participants express difficulty in transitioning from pendulum-like thinking to the specifics of this rolling disk scenario.
There are various lines of reasoning being explored, including attempts to relate the system to a pendulum and considerations of energy conservation. Some participants have offered hints and suggestions, but there is no explicit consensus on the best approach yet.
Participants note challenges with the setup of the problem, including the need to account for the point mass's contribution to the system's dynamics and the complexities introduced by the rolling motion.
vladimir69
A point mass m is attached to the rim of an otherwise uniform solid disk of mass M and radius R (in the diagram mass m is in contact with the ground). The disk is rolled slightly away from its equilibrium position and released. It rolls back and forth without slipping. Show that the period of this motion is given by
[tex]T=2\pi \sqrt{\frac{3MR}{2mg}}[/tex]
[tex]I=\frac{1}{2}MR^2[/tex]
[tex]I \frac{d^2 \theta}{dt^2}=-\kappa \theta[/tex]
[tex]\omega=\sqrt{\frac{\kappa}{I}}[/tex]
[tex]T=\frac{2\pi}{\omega}[/tex]
[tex]\alpha = \frac{d^2\theta}{dt^2}[/tex]
My guess would have been
[tex]I=\frac{1}{2}MR^2 + mR^2[/tex]
and then
[tex]I\alpha = -mgR\sin\theta \approx -mgR\theta[/tex]
now we have kappa and I so we can pop that into solve for T which gives a big mess. This problem is a bit tricky for me as I am trying to look for a stationary axis to take torques about and not sure about how to apply the parallel axis theorem with the point mass (do I even need to use it?). I tried calculating the centre of mass of the disk just for kicks and it turned out to be a point 2/3R from the centre (using Centre of Mass = [itex]\int r dm[/itex]) but it should be in the centre...thats another story.
It seems there must be a pretty easy way to solve it but I can't see it.
vladimir69 said:
A point mass m is attached to the rim of an otherwise uniform solid disk of mass M and radius R (in the diagram mass m is in contact with the ground). The disk is rolled slightly away from its equilibrium position and released. It rolls back and forth without slipping. Show that the period of this motion is …
… I am trying to look for a stationary axis to take torques about …
Hi vladimir69! :smile:
Hint: conservation of energy :wink:
Thanks for the reply
Not sure how using conservation of energy will allow me to find the period of oscillations for this problem. Not 100% sure how to apply conservation of energy for this problem either.
I am tempted to work it out by trying to find a way so that (analogous to a pendulum)
[tex]\frac{1}{2}MR^2\alpha=-\frac{1}{3}mgR\theta[/tex]
because from the above equation you can get omega and then immediately go to the period T using [itex]T=2\pi\frac{1}{\omega}[/itex]
edit: not sure why my latex is not showing correctly, it is displaying stuff I made in previous posts.
[tex]\frac{1}{2}MR^2\alpha =-\frac{1}{3}mgR\theta[/tex]
vladimir69 said:
i am still working on it but can't proceed
my brain is still stuck in thinking of pendulums and not of conservation of energy
[tex] \frac{1}{2}MR^2\alpha=-mgR\theta[/tex]
thats my pendulum equation for this system but its missing a factor of a 1/3
hope you can help
thanks tiny tim
Hi vladimir69! Thanks for the PM. :smile:
I think conservation of energy is the easiest way …
the KE of the disc is its linear KE (1/2 Mv2) plus its rotational KE (1/2 Iθ'2) …
(and add the KE of the point mass, but you should find that it's second-order and can be ignored :wink:)
and the PE is mgR(1 - cosθ), ~ 1/2 mgRθ2
then write v as a function of R and θ, ignore anything of second order in θ,
and the equation KE + PE = constant should give you
(something)θ'2 + (something else)θ2 = constant,
which you can then solve. :smile:
  • · Replies 42 ·
  • · Replies 28 ·
  • · Replies 97 ·
