Advising on Heat Pump Efficiency for 1500J at 280K
The discussion focuses on evaluating the efficiency of a heat pump that delivers 1500J to a room at 280K while consuming 50J of work per cycle, extracting heat from a surrounding environment at 270K. The key metric for assessing heat pump efficiency is the Coefficient of Performance (COP), calculated as COP = Q1/W, where Q1 is the heat delivered to the hot bath and W is the work input. Participants emphasize comparing the claimed COP with the theoretical maximum COP derived from the Carnot Cycle for the given temperatures to validate the heat pump's performance.
  • Understanding of thermodynamic principles, specifically heat pumps
  • Familiarity with the Coefficient of Performance (COP) concept
  • Knowledge of the Carnot Cycle and its implications for efficiency
  • Basic mathematical skills for calculating efficiency ratios
  • Research the Carnot Cycle and its efficiency calculations for heat pumps
  • Learn how to calculate the Coefficient of Performance (COP) for various heat pump systems
  • Explore real-world applications and limitations of heat pumps in different temperature environments
  • Investigate advanced thermodynamic cycles that improve heat pump efficiency
Engineers, thermodynamics students, and HVAC professionals seeking to understand heat pump efficiency and performance evaluation methods.
captainjack2000
The question asks us to advise the company on a heat pump (and give reasons) which is claimed to deliver 1500J to a room at 280K by consuming 50J of work per cycle pumping heat from the surroundings at 270K.
I've drawn a diagram of the heat pump, taking heat Q2 from a bath of 270K up to an engine/refrigerator into which goes work W=50J, from which heat Q1 goes into hot bath of 280K. I am a bit confused about what to do next.
Is it that the efficiency of a heat pump is = Q1/W = Q1/ (Q1-Q2) = ?
thanks
It's actually referred to as "coefficient of performance" or COP, but yes that is the right idea.
Compare the claimed COP with what you'd get for a Carnot Cycle heat pump operating at those temperatures, to determine whether this COP is possible.
  • · Replies 30 ·
  • · Replies 19 ·
