Solution of Euler Differential Equation Using Ansatz Method
The discussion revolves around solving an Euler differential equation of the form x²y'' + 3xy' - 3y = 0 using the ansatz method with the proposed solution y(x) = cx^m, where c and m are constants.
  • Exploratory, Assumption checking
  • Participants attempt to derive the characteristic equation from the proposed ansatz and question whether the constant c can be determined given the absence of initial conditions. There is also a discussion about potential typographical errors in the equation setup.
The discussion is ongoing, with participants exploring the implications of the derived values for m and questioning the role of the constant c in the absence of initial conditions. Some participants express uncertainty about the correctness of the original equation.
There are mentions of technical issues with LaTeX formatting in the posts, which may affect clarity. The lack of initial conditions is noted as a constraint in determining the constant c.
dave4000
Solve the euler differential equation
[tex]\x^{2}y^{''}+3xy'-3y=0[/tex]
[tex] \int_X f = \lim\int_X f_n < \infty[/tex]
by making the ansatz [tex]y(x)=cx^{m}[tex], where c and m are constants.<br /> <br /> <h2>The Attempt at a Solution</h2><br /> <br /> [tex]y(x)0=c^{m}[tex] [tex]y^{'}(x)=cm^{m-1}[tex] [tex]y^{''}(x)=cm(m-1)^{m-2}[tex] <br /> [tex]m(m-1)+3m-3=0[tex] [tex]m^2+2m-3=0[tex] [tex](m-1)(m+3)=0[tex] [tex]m=-3 or m=1[tex] <br /> Is this the solution or can c be found?[/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex][/tex]
Latex isn't working on this post so here it is without Latex:
x^{2}y''+3xy'-3y=0
by making the ansatz y(x)=cx^{m}, where c and m are constants.
y(x)=cx^{m}
y'(x)=cmx^{m-1}
y''(x)=cm(m-1)x^{m-2}
m(m-1)+3m-3=0
m^2+2m-3=0
(m-1)(m+3)=0
m=3 or m=-1
Latex maybe out due to technical problems.
Is one sure of the function before the y' term - 3x^{2}?
*Correction made* :)
This was merely a typo, the orignal problem still remains...
so...er...c?
since no innitial conditions were given i shall take irt that c cannot be found.
  • · Replies 18 ·
11K
