Mass concentrated at a single point?
  • Context: High School
  • Thread starter Thread starter xxariesxx
    Mass Point
The discussion centers around the concept of mass concentration in physics, specifically whether the mass of an object, such as a wooden sphere, can be thought of as being concentrated at a single point, like its center of mass. Participants explore the implications of this idea in both mathematical and conceptual contexts.
  • Some participants suggest that thinking of mass as concentrated at a single point is a useful conceptual simplification, rather than a strict mathematical device.
  • Others argue that this simplification involves replacing an extended object with a point object located at the center of mass, which is a conceptual tool for problem-solving.
  • A participant elaborates on the process of building up a shape by placing identical masses and calculating the center of mass, illustrating how the average position of mass contributes to the center of mass concept.
  • Another participant discusses the implications of treating a system of particles as a single giant particle, showing how this approach simplifies calculations while yielding the same results as treating each particle individually.
Participants express varying views on the nature of the mass concentration concept, with some emphasizing its conceptual utility and others focusing on its mathematical aspects. The discussion does not reach a consensus on the characterization of this concept.
There are unresolved nuances regarding the definitions of mathematical versus conceptual devices, as well as the implications of simplifying complex systems into point masses. Participants acknowledge these complexities without reaching definitive conclusions.
xxariesxx
I'm trying to understand this concept. For example if there is a wooden sphere and we said that all of its mass is concentrated at a single point, can I think of this as the mass of the entire sphere being contained in one of its atoms?
Welcome to PF.
No need for atoms here - this is just a useful mathematical device for solving problems. You don't have to try to visualize it relating to reality.
Minor quibble- it's not a mathematical device, it's a *conceptual* device. Replacing an extended object with a point object located at the center of mass, having the same mass as the original object is a conceptual simplification.
Any compound system is described with its center of inertia coordinates (they do not correspond to a real material point-like heavy particle) and with the relative coordinates.
It is not a replacement of objects, it is a variable change.
When you describe your wooden sphere with only its center of inertia coordinates, you know what a "simplification" you do - you just omit the relative coordinate equations.
Bob.
Let's say we want to build up a shape of mass (a sphere, for example), i.e. by repeatedly placing identical masses of [itex]dm[/itex] until we've made our shape and keeping track of their centre of mass (which is a [itex]dm\mathbf{r}[/itex]. If we have two particles we get
[itex]\frac{dm\mathbf{r_1}+dm\mathbf{r_2}}{2dm}[/itex]
if we have three we have
[itex]\frac{dm\mathbf{r_1}+dm\mathbf{r_2}+dm\mathbf{r_3}}{3}[/itex]
and so on. All we're finding is the average here. Now let's say the 4th mass, as an example, lies at exactly the same place as where the second mass placed was (i.e. there is more mass at that position) then our sum becomes
[itex]\frac{dm\mathbf{r_1}+dm\mathbf{r_2}+dm\mathbf{r_3}+dm\mathbf{r_4}}{4}[/itex]
but [itex]r_4=r_2[/itex], therefore, we can say
[itex]\frac{dm\mathbf{r_1}+2dm\mathbf{r_2}+dm\mathbf{r_3}}{4}[/itex].
Hopefully from here you can see how we arrive at the center of mass concept
Now, the reason we do this is because it ends up simplifying things conceptually but keeping the identical mathematics. It kinds puts the many-body aspect (the fact that we're dealing with a ton of different masses) under the rug, so to speak. To demonstrate, let's take two time derivative of our center of mass. and since our masses are constant in time the derivative only acts on our [itex]\frac{d^2\mathbf{r_i}}{dt^2}=\frac{\mathbf{v_i}}[/itex] so our center of mass equation becomes:
[itex]\frac{d^2\mathbf{R_{CM}}{dt^2}=\mathbf{A_{CM}}=\frac{\Sigma_i m_i \mathbf{a_i}{M}[/itex]
Now if we times this by our total mass ([itex]M=\Sigma_i m_i[/itex]) we get:
[itex]M\mathbf{A_{CM}}=M\frac{\Sigma_i m_i \mathbf{a_i}}{M}=\Sigma_i m_i \mathbf{a_i}[/itex]
which we see is exactly the equation for the total net force of a system of particles [itex]\Sigma_i m_i \mathbf{a_i} = \Sigma_i \mathbf{F_i} = \mathbf{F_{total}}[/itex]
so we see that by treating the system as a single giant particle of mass M and position [itex]\mathbf{R_{CM}}[/itex] we get the exact same result as if we'd just treated each particle individually. It's just a lot easier.
  • · Replies 41 ·
  • · Replies 38 ·
  • · Replies 60 ·
  • · Replies 23 ·
