Finding the Cross Product and Angle Between Two Vectors
  • Thread starter Thread starter yb1013
    Vectors
The problem involves two vectors, A and B, defined in a 2D space, and requires finding the cross product and the angle between them. The original poster expresses confusion regarding the calculation of the angle after determining the cross product.
  • Mixed
  • The original poster attempts to calculate the cross product and subsequently the angle using the cosine formula, but encounters difficulties with the angle calculation.
  • Some participants suggest that the cosine of the angle requires the dot product instead of the cross product, indicating a misunderstanding of the operations involved.
  • Others highlight the importance of understanding the definition of the cross product and its applicability in 3D space.
The discussion is exploring the correct methods for calculating the angle between the vectors, with some participants providing clarifications regarding the use of the dot product versus the cross product. There is acknowledgment of the original poster's confusion, and guidance is offered regarding the definitions and appropriate contexts for these vector operations.
There is a mention of the vectors being in 2D space, which raises questions about the validity of using the cross product in this context. The original poster's calculations appear to be based on an assumption that may not align with the dimensionality of the vectors.
yb1013
Two vectors are given by Avec = -1 i + 2 j and Bvec = 4 i + 2 j
Find A X B
Find the angle between A and B
Okay well I got the First part of the problem, I know that A X B is -10, but when I do everything for the angle I keep getting the wrong answer.
After I finish with my calculating I come up with cos (theta) = -10/10 which would simplify to 180 degrees, but that's wrong...
Can someone please help me out, I don't understand where I am going wrong
Thank You!
If you want the cosine of the angle you need the dot product (not the cross product).
The angle is 90 deg, the two vectors are perpendicular.
If you use the cross product, you'll get sin (theta)=1 and theta = 90 deg.
oo ok, thank you
It's important to remember how the cross-product is defined before you look at this problem. The cross-product is an operation in a 3-D vector space that produces a third vector.
In this case:
(-1, 2, 0) [tex]\times[/tex] (4, 2, 0) = (0, 0, -10)
The cross product also gives you:
[tex]a \times b = \sin{\theta} \nhat[/tex]
You might have an easier time looking at the dot product only.
But if your 2D vectors aren't actually lying in a 3D space, do not use the cross product at all, as it is not well defined.
  • · Replies 26 ·
