Thread Closed
electrical resistance
Share Thread Thread Tools
Apr21-09, 11:10 AM   #1
lets say i have a block of material, measures a,b,c (length width height) and two wires running in from the top, both with circular cross section, radius r, distance d from the edges
Code:
    ____________________
   /  d            d   /|
  /<--->O       O<--->/ |
 /___________________/  |
 |                   |c |
 |___________________|/ b
           a
if i were to let electrical current through the block, measure the current and voltage i could find its resistance. But how would i calculate it theoretically if i knew the specific resistance of the material? I have no idea how to do that because i cant imagine how the current would go through the block, i mean through what path.
Or, lets create a more general problem:
lets say i have a space filled with material, measurements infinite (fills up all the space), specific resistance known, and two wires (isolated from the material) (sames as before, circular cross section and radius r) running in from infinity with end points at distance L.
Code:
                     L
so what i need to know what the path of the current looks like (its diffuse of course but the further away from the shortest path the less current takes that path)
what i'm actually trying to understand is how electric current moves in human body if i would place electrodes on the skin and apply some voltage, but the geometry of this is nontrivial, which i have not seen before while solvin 'find the resistance of blah blah blah' kind of problems
thanks for any hints
PhysOrg.com
PhysOrg
physics news on PhysOrg.com
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> New analysis yields improvements in a classic 3D imaging technique
>> Research effort deep underground could sort out cosmic-scale mysteries
Apr21-09, 11:56 AM   #2
Recognitions:
Homework Helper Homework Help
Resistance = rho * L / A
rho is the resistivty of the material
L is the distance between the points
A is the cross section area
Apr21-09, 11:19 PM   #3
Recognitions:
Gold Membership Gold Member
Is it AC or DC current? Do the wires run through the whole bulk of the material or are they just probes on the surface?
If they are just probes, then I think you could probably estimate them as cylinders or points of potential and solve something like a Poisson's equation to find the voltage field. If you it is an AC current with wires that penetrate through then it could be easily estimated by solving for the fields of a simple twisted pair transmission line in a lossy medium (provided you estimate the bulk to be infinite).
I think it all depends on how you want to model this.
Thread Closed
Thread Tools
Similar Threads for: electrical resistance
Thread Forum Replies
Electrical Resistance Introductory Physics Homework 2
Electrical Resistance Exercise, please help. Introductory Physics Homework 1
Electrical= Resistance and Energy Introductory Physics Homework 4
Electrical Resistance of a brick Introductory Physics Homework 2
Electrical Resistance Classical Physics 3
