Rotational Mechanics(The concept of spinning)
The discussion revolves around a problem in rotational mechanics involving a sphere (specifically a tennis ball) that falls freely and subsequently bounces after hitting the ground. The problem includes considerations of angular velocity, the coefficient of restitution, and friction, with the goal of determining the range of the sphere after the bounce.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss using energy conservation to find velocities and question the application of angular momentum conservation. There are attempts to derive equations related to the motion and impact of the sphere, with some participants expressing uncertainty about specific formulas and their derivations.
The discussion is active, with participants exploring various approaches to the problem. Some have provided insights into the mechanics involved, while others are seeking clarification on specific concepts and formulas. There is a recognition of the complexity of deriving the necessary equations, and participants are engaging in a collaborative effort to understand the problem better.
Participants note the challenge of deriving equations without visual aids and express the need for clarity on the relationships between linear and angular quantities. There is an acknowledgment of the assumptions made regarding initial conditions, such as the sphere's vertical drop and lack of initial horizontal velocity.
FedEx
well this is a really good question which i just thought while playing cricket.
A sphere of mass m and radii r(a tennis ball) falls freely from a height of H and angular velocity(clockwise) about its axis omega.Coefficient of restitution is e
The coefficient of friction is mu.
After the sphere touches the ground it moves in the forward direction.
We have to find the range of the sphere.
Now we can find the velocities by energy conservation.
We we can apply angular conservation about the point which touches the ground.
initial translational + initial rotational = final translational + final rotational
Final velocity * e = Initial velocity.
Lets suppose that after collision the velocities of the sphere is vx and vy. so we have four variables final angular velocity,final velocity,Vx and Vy.
But we have just two equations. we can get one more by angular conservation which i am unable to get through and we are still one short.
Using energy to find velocities is a crock usually.
You can treat the vertical and horizontal comonents separately.
You know how high i'll bounce from COR*inital h. so you can work out the vertical component of velocity.
the forward motion will depend on rotational speed, moment of inertia, radius and initial sideways velocity (which in this case is zero as its a verticl drop). I really can't be bothred deriving the equation you'll have to do that one yourself.
I didnt tell you to derive any equation. I am waiting for an insight to the problem. That how can we apply angular conservation. You have just told me the things which i know already except the way in which we can find Vy. But you have failed to give any other insight so that i can develop an equation for angular momentum
Oh don't get me wrong, I know you didn't ask me to derive it. I didnt meant to imply that you did or that you were being lazy or anything like that. Sorry, I didnt mean for the post to come across in a harsh manner.
It's just that to he honest I couldn't remember the below formula and couldn't derive it when I wrote that, but didnt want to admit it! :D
I've been looking through my notes on oblique impacts and found this.
Vxnew = (Vx + Awr) / (1+A)
where A = I / ma^2
Set the inital velocity in x to be zero due to the vertical drop and bobs your uncle. This is a model for impacts that involve rolling when contact occurs. Which is the only thing that can happen in this case due to no horizontal inital velocity.
where A = I / ma^2
Sorry chris... I was a bit harsh too.I didn't knew that you were such a cheery guy.
Now back to the problem.
I am not able to understand how we get the formula mentioned by you. Do you know its possible derivation?
i'll have a crack at it. It's goig to be diffucult to get across on here. it'll probably need a diagram to help explain. also can someone please check I haven't messed up the derivation.
m=mass
r=ballradius
T=torque
F=force
I=moment of inertia
w=angular velocity
We start off with:
F=ma
that can be rewritten as the integral, so we can get the inital and final velocities.
Fdt=mdv
F=m(vi - vf) (1)
Now we know that as the ball is spinning and it hits the ground, a force in x will occur. This force acting at the contact patch acts as a torque on the ball.
T=Fr
Like F=ma this can be rewritten as the integral to get.
T=I(wi-wf)
Fr=I(wi-wf) (2)
We also know that after impact, converting angular velocity to linear velocity we have.
vf=wf*r (3)What we do is then is:
rearrange (2) for F and put this into the rearranged F=ma. equation 1
F=(I(wi-wf))/r
(I(wi-wf))/r = m(vi-vf)
This gives us a problem as we don't know either vf or wf. However we do have equation 3 so we can rwrite it as 1 unknown. As we want to know vf, we rewrite wf in terms of this.(I(wi-wf))/r = m(vi-vf)
wf=vf/r
(I(wi-(vf/r)) = M(vi-vf) (4)
4 can be expanded and rearranged to get
Vi - (Iw/rm) = Vf ((I/r^2m) + 1)
That is the derevation. The eqaution can be used in the form above. But to make it look tidy, we rewrite the left ahnd bracket multiplied by r/r.
Vi - (Iwr/r^2m)
Vi - (Iw/r^2m)r
The (Iw/r^2m) was given the label A to make it easier to write. Tidying up the eqaution gives.
Vf = (Vi + Awr)/(1+A)
As there is no inital velocity in x. we have.
Vx final = Awr/(1+A)
Okey... I got the concept. Let me derive the formula on my own from the points which you have made. And let's see if it matches yours
  • · Replies 32 ·
  • · Replies 33 ·
