Solve Functional Equation & Find Limit: f(x+y)=(f(x)+f(y))/(1+f(x)f(y))
  • Thread starter Thread starter ritwik06
    Functional
The discussion revolves around a functional equation involving a function f defined by the relation f(x+y) = (f(x)+f(y))/(1+f(x)f(y)) for all real x and y, along with additional conditions regarding its derivative and range. The original poster attempts to show that the function is increasing and to evaluate a limit as x approaches infinity.
  • The original poster explores the implications of setting x and y to zero and differentiating the functional equation. They question the value of f(0) and its impact on the function's behavior. Other participants suggest using the known behavior of the hyperbolic tangent function as a potential guide and discuss proving that f(x) could be tanh(x) through limits and differential equations.
Participants are actively engaging with the problem, offering hints and alternative approaches. There is a suggestion to explore the limit of f(y) as y approaches infinity, and some guidance on using l'Hôpital's rule for evaluating the limit involving f(x). The discussion remains open with various lines of reasoning being explored.
There is an emphasis on the constraints of the function, particularly its range and the behavior of its derivative. The original poster expresses difficulty in evaluating the limit, indicating a need for further exploration of the functional equation's implications.
ritwik06
Suppose a function satisfies the conditions
1. f(x+y) = (f(x)+f(y))/(1+f(x)f(y)) for all real x & y
2. f '(0)=1.
3. -1<f(x)<1 for all real x
Show that the function is increasing throughout its domain. Then find the value:
Limitx -> Infinity f(x)x
I proceed by putting x,y=0 in eq 1.
I get the following roots for f(0)={-1,0,1}
But if I take f(0)={-1,1}, f(x) will become a constant function and will be equal to +1 when f(0)=1 and -1 when f(0)=-1, thereby violating condition 3
So f(0)=0From equation 1: I assume 'y' as a constant and differentiate wrt x
f ' (x+y)=(f ' (x)(1-f2(y))) / (1+f(x)f(y))2
I put x=0;
I get f ' (y)=1-f2(y) Using condition 3; I prove that the derivative is always positive.
I have been able able to solve the first part of the question. But I couldn't evaluate the limit
Limitx -> Infinity f(x)x. Please help me on the limit part.
It may be helpful to "cheat" and use the fact that f(x) is really tanh x, to figure out what to do. Then go back and do it without using that fact.
First show lim f(y)=1 as y approaches infinity.
After that, then you find your limit, which has indeterminate form 1^infty, by using natural log and l'Hopital, just like you would do if you knew f was tanh. Unfortunately with f, you don't have all the trig identities at your disposal. Take a stab at it and ask again if you get stuck.
You could take Billy Bob's hint farther and prove that f(x) really is tanh(x). Take f(x+e) (e is epsilon). Put that into your formula for f and rearrange it into a difference quotient and take the limit as e->0. Notice since f'(0)=1, lim f(e)/e ->1. That will give you a differential equation to solve for f.
Thanks a lot for helping me solve my problem :D
  • · Replies 20 ·
