Titration of HBrO: Calculating pH of KOH Volumes
The discussion revolves around the titration of a weak acid, HBrO, with KOH, focusing on calculating the pH at various volumes of KOH added. Participants explore the pH at different stages of the titration, including before, at, and after the equivalence point.
  • Homework-related
  • One participant outlines the initial conditions and calculations for pH at different volumes of KOH, noting confusion specifically at the equivalence point.
  • The participant calculates the concentration of the conjugate base BrO- after the addition of KOH and sets up an ICE table to find the pH at the equivalence point.
  • Another participant emphasizes that beyond the equivalence point, the pH is determined by the concentration of excess hydroxide ions.
  • A later reply reveals that the original poster realized they had miscalculated the concentration of excess hydroxide, leading to a corrected pH calculation for the final part of the titration.
  • Participants reference the Henderson-Hasselbalch equation and its applicability in this context, indicating some confusion about its use in calculating pH at different stages.
There is no consensus on the pH values calculated for the different stages of the titration, particularly regarding the pH after the equivalence point. Participants express differing views on the correct approach to calculating pH in these scenarios.
Participants discuss the assumptions made in calculations, such as the approximation of x being small in the ICE table. There is also mention of the total volume affecting the concentration of hydroxide ions, which may not have been fully resolved in earlier calculations.
This discussion may be useful for students studying acid-base titrations, particularly those seeking to understand the behavior of weak acids and the calculations involved in determining pH at various points in the titration process.
osker246
Consider the titration of 20.0mL of a 0.100 M solution of HBrO, a weak acid (Ka=2.5x10-9) with 0.200 M KOH. Calculate the pH of the following volumes of KOH.
a. 0.00mL
b. 5.00mL
c. 10.00mL
d. 30.00mL
pH=pKa +log [base]/[acid]
Im having trouble with C when the pH is at its equivalance point.
so,
10.00mL (.200 mmol KOH/mL) = 2.00 mmol OH-
So stoichiometricaly my OH- and HBrO are used to completely to give me a conjugate base of 2.00 mmol BrO-
[BrO-]=2.00mmol/30.00ml=.0667 M
I set up my ice chart:
BrO-<=====>OH-+HBrO
I .0667 0 0
C -x +x +x
E .0667-x x x
Where
Kb=[OH-][HBrO]/[BrO-]=x2/.0667-x=4.0x10-6
Assume x is small to find x=[OH-]=5.2x10-4
pOH=3.28
pH= 14-pOH=10.72
What doesn't make sense to me is in Part A pH=4.80, part B pH=8.5, Part C=10.72 and part D pH=8.20.
Now shouldn't the pH in part D be greater than part C since I have excess OH-?
I'll type of my work for Part D in a bit. I have to leave right now. But if somebody can help my checking my answers I'd appreciate it. Thanks.
When your solution is far past the endpoint, the pH only depends on the excess hydroxide. How much or what is the concentration of the excess hydroxide? This helps to give you your pH calculation. pH + pOH = 14.
Ohhhhhhhh!
I see what I forgot to do. I knew that once past the end point the only thing affecting pH was excess hydroxides. I just forgot to properly calculate the concentration. I tried using the henderson-hassalbach(sp?) equation instead. So since I have an excess of 4.00 mmol of hydroxide and a total volume of 50.00mL, [OH-]=.0800 M. So leaving me with a final pH of 12.903 for part D. Thank you very much!
  • · Replies 23 ·
