Electrostatic field ( Gauss Law )
The discussion focuses on calculating the electric field intensity at a specific point due to an infinitely long line charge of 50 pC/m, positioned parallel to the y-axis. The electric field intensity formula used is E = (ρ / (2πε₀r)), where ρ is the charge density and ε₀ is the permittivity of free space. The calculated electric intensity at point (-1, 5, -3) is -0.18(ax0.6 + az0.8)(V/m). The solution emphasizes the importance of determining the perpendicular distance from the point to the line charge rather than the distance to an arbitrary point on the line.
  • Understanding of Gauss's Law and its application to electric fields
  • Familiarity with vector calculus and coordinate systems
  • Knowledge of electric field intensity calculations for line charges
  • Basic principles of electrostatics and charge distribution
  • Study the derivation of Gauss's Law for different charge distributions
  • Learn about electric field calculations for various geometries, including cylindrical and spherical charges
  • Explore the concept of electric field lines and their visual representation
  • Investigate the role of permittivity in electric field calculations, particularly in different media
This discussion is beneficial for physics students, educators, and anyone studying electrostatics, particularly those focusing on electric fields generated by line charges and applying Gauss's Law in practical scenarios.
Saru
Assuming that an infinitely long line charge of 50(pC/m) parallel to the y-axis at x=2(m) and z=1(m), determine the electric intensity at the point (-1, 5, -3).
The answer given : -0.18(ax0.6 + az0.8)(V/m)
Electric field intensity due to an infinite straight line charge of uniform density :
E= ar("rho" / (2"pi""epsolon 0"r) ( V/m)
I let point P = -ax + ay5 - az3
Point on line perpendicular to point P, Q = ax2 + az
Vector Q to P = -ax3 + ay5 - az4
I found out that if i ignore or make coefficient of ay to zero and apply the above formula i'll get the answer..
but i do not understand why..please help
Hi Saru,
Draw a picture and you will see the reason immediately. You are not looking for the distance from P to Q, but from P to the line of charge.
  • · Replies 16 ·
  • · Replies 83 ·
