Can a small shock from a lighter be more dangerous than a wall socket?
  • Context: Undergrad
  • Thread starter Thread starter thepopasmurf
The discussion revolves around the comparative dangers of electric shocks from a lighter versus a wall socket. Participants explore the underlying physics of voltage, current, and their effects on the human body, touching on concepts such as energy dissipation and the physiological impacts of electric shocks.
  • Some participants suggest that while high voltage can produce a shock, it is the current that ultimately causes harm or death, as exemplified by the operation of devices like tasers.
  • Others argue that the duration of the shock is critical, with brief shocks from devices like lighters not delivering enough energy to cause significant harm.
  • One participant notes that the path electricity takes through the body is important, indicating that touching a high voltage source with both hands can be more dangerous than with one hand.
  • Another participant mentions that lower voltages can be safer, while certain higher voltages can cause the heart to contract in a way that may prevent lethal arrhythmias.
  • There is a discussion about the specific voltage of piezoelectric lighters, which can reach around 15,000V, but the current is limited in duration, reducing potential harm.
  • One participant shares a personal anecdote about experiencing a shock while unplugging a refrigerator, linking it to a dream, which introduces a more subjective perspective on the topic.
Participants express differing views on the relationship between voltage, current, and the resulting danger of electric shocks. There is no consensus on the relative dangers of the lighter versus the wall socket, as various factors such as duration, path of current, and physiological responses are debated.
Participants reference the V=IR relationship and discuss the implications of resistance and current flow in the human body. There are mentions of specific voltage thresholds and their effects on heart function, but these points remain contested and not fully resolved.
thepopasmurf
My friend has been shocking me and friends with part of something (a lighter maybe) he found. We even got the shock to go through a ring of us. I'm sure that the thing produces a large voltage because it can spark.
My question is why can a wall socket which has relatively low voltage (230 here) shock someone to death and the little thing cannot. My mind keeps on coming back to the V=IR relationship.
Generally high voltage comes with quite a bit of current (but also used to circumvent this: the large power lines carry high voltage with low current to try to overcome resistance over vast distances). But the part of this equation that can kill you is the current. This is also why there's the famous picture of a volunteer (oops had Tesla apparently wrong) sitting and reading under the sparks of a massive Tesla coil with no ill harm. Its a high voltage low current environment. Or at least that's what I've gathered, I'm not too fond of electricity, both in equations and to my body lol.
It is the voltage that shocks you. But it is the amount of energy dissipated in your body that kills you. The energy is a function of current and how long it is sustained for.
If you are connected to the wall socket, a constant electric current passes through you because the voltage is sustained indefinitely. The shock from the device in question lasts for a tiny fraction of a second so there is not much energy dissipated in your body.
AM
it's the current that will harm,(kill) you not the voltage. Like the ''tazer'' the police have has high voltage, like, maybe 1,000, but it's produced by a small battery, so it'll shock you but not kill you, because there is very little current. Large current is produced at the electric plant by generators, be it coal, deisel gas, or water at the dam turning over the generators. There is a lot of energy behind the voltage, meaning lots of 'free electrons' will flow, this is called 'current'..The more electrons, the higher the current. It is said only 1/10 of 1 AMP(the measure of current) could kill you. Another twist is when there is lots of resistance to the current, then not many electrons will flow, hence low current. Your body is mostly liquid so it doesn't have much resistance to electron flow, (like rubber or wood or plastic or glass does), so when you put finger in socket you are going to get shocked big time,( high current). WE humans' hearts don't like all those electrons charging thru it. IN theory, if you have rubber soles on or are standing on a wood floor, with ur finger in socket, you won't get shocked. BUT you better not be touching the wall with the other hand, cause the current/voltage will go in that direction, not to your feet. REMEMBER the current takes the path of least resistance,(meaning highest current), to "ground"., "ground" meaning something that (will allow the voltage to pass) is attached to the earth. The voltage always tries to go to "ground", to complete the path, and whatever/whoever it goes thru will get the shock.
That's 50,000 and the frequency is attuned to the human neural system to interrupt impulses.
Yes, that is often the prevailing wisdom, but be careful. Even at low amperage, if your heart gets confused by the voltage and frequency, it will fibrillate. And that will kill you.
I remember seeing a plot of the "lethality" of electric shocks years ago. Lower voltages are safer. And surprisingly, higher voltages (like 300) are safer also. This is because they "lock up" the heart in a contraction, so when the shock ends, the heart's muscles are still in sync.
But right around 120, which is the voltage in US homes, the shocks are the most dangerous because they force the heart's muscles out of sync. That's a real bummer, but there's probably no hope of changing the standard now.
Can't emphasize that bit about the frequency enough!
well i have a question too. I was playing a trick on my brother, because he has a mini refridgerator, in his room that holds all of his pop, and when I unplugged it and when I unplugged it I got shocked and then like a week later I had a dream about a show called RESPECT to teach you about bullying at my school, and then, just today we had those same speakers in my dream, at our school. So I think I'm physics or maybe that just happens or something if you have any good information please write back. THANKS :)
A lot depends on the route the electricity takes through your body. That's why a lot of TV repairers (in the good old days when TVs were actually repaired rather than just thrown away) used to work with one hand in their pocket.
The reason is that if the other hand touches a high voltage the current should (in theory !) run down the side of the body to Earth and miss the heart.
If, however, one hand touched a high voltage and the other hand was in contact with something earthed, the current would flow across the chest where the heart is, potentially lethally.
The Voltage of the piezoelectric lighters is quite high around 15000V. If we discard capacitive effects the current does indeed go quite high, but it does not have time to do much damage, the amount of power stored in one such pulse is limited by the energy that you put into the "snapper". This limits how long the current can flow.
It is a similar thing with force or acceleration for that matter. Fighter planes can produce 9g and many people already go unconscious there. But there have been cases of people surviving more than 100g because it was for a very short time. If you remember how much work it is, to run something like a tiny light bulb of a bicycle by muscle power, you can imagine that the piezo cannot deliver much of "a punch" to your heart.
  • · Replies 28 ·
  • · Replies 52 ·
9K
  • · Replies 26 ·
  • · Replies 66 ·
