Compiling Source Code on Linux (MINT) - Assistance Needed!
  • Thread starter Thread starter okwatia
    Code Source
The discussion revolves around issues encountered while compiling source code on Linux Mint, specifically focusing on an error message indicating that the C compiler cannot create executables. Participants are seeking assistance with troubleshooting this compilation problem.
  • Technical explanation, Debate/contested, Homework-related
  • One participant reports an error message during compilation, specifically stating that the C compiler cannot create executables.
  • Another participant asks for the command line being used to compile the code, indicating a need for more information to assist.
  • A third participant explains the role of the 'configure' script in generating a makefile and requests the exact error message to better understand the issue.
  • The error message provided indicates a failure in creating executables, prompting suggestions to check the config.log file for more details.
  • Some participants suggest potential causes for the error, including lack of write permissions in the directory, absence of gcc and g++ installations, or a faulty installation.
  • One participant recommends installing build-essential packages on Ubuntu/Debian systems as a possible solution.
  • Another participant inquires if the user has attempted to run the compilation command as a superuser using sudo.
Participants present multiple potential causes for the compilation issue, indicating that there is no consensus on the exact problem or solution at this time.
Limitations include the lack of specific details regarding the user's environment, such as permissions and installed packages, as well as the absence of information from the config.log file.
Users experiencing similar compilation issues on Linux Mint or other Debian-based systems, as well as those interested in troubleshooting compilation errors related to C programming.
okwatia
Whenever i try to compile source code of programs in linux (MINT) it tells me that it cannot compile executables. Can someone help me?
What is the command line you are typing?
'configure' is a special command script that works out what kind of Unix you have and builds a makefile.
I've never heard of that error - can you post the exact error message?
Did you write the config script - where was it from
This is the error message:
checking build system type... i686-pc-linux-gnulibc1
checking host system type... i686-pc-linux-gnulibc1
checking for gcc... gcc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
Check the command in config.log
It could be that you don't have write permission to the dir that you are running this in.
Other people suggested that it occurs if you don't have gcc AND g++ installed, or have a faulty install.
On ubuntu/debian try "apt-get install build-essentials"
Did you try running it as a superuser (using sudo) ?
  • · Replies 0 ·
  • · Replies 29 ·
10K
