Magnetic flux and emf through a rotating ring
The problem involves a rotating metal ring in a magnetic field, focusing on calculating magnetic flux and induced electromotive force (emf) as functions of time. The subject area pertains to electromagnetism and rotational dynamics.
  • Participants discuss the relationship between magnetic flux and emf, with one noting the formula for magnetic flux and its derivative for emf. Questions arise regarding the implications of the ring's rotation about a diameter and the correct application of signs in the equations.
The discussion is active, with participants clarifying mathematical expressions and questioning the physical setup of the problem. Some guidance has been offered regarding the interpretation of the rotation axis, but no consensus has been reached on the implications of this detail.
Participants are navigating potential confusion regarding the rotation of the ring about a diameter and its effect on the calculations. There is also a mention of a possible sign error in the expression for emf.
captainjack2000
Sorry I don't quite know how that happened!
Any way the question is
"A metal ring of radius R rotates with constant angular velocity about a diameter. Perpendicular to the rotation axis is a constant magnetic field B. Calculate as functions of time
a) magnetic flux through ring
b) emf induced
I know magnetic flux = BAcoswt
so emf = -magnetic flux/dt = ABwsinwt
arent you missing a minus sign in your final answer?
emf = -dphi/dt = -d/dt(BAcoswt) = -(-BAwsinwt) = ABwsinwt
i think
I am a bit confused by the fact that they say "about a diameter" how does this change things?
ok. yeah my bad with the minus. the diameter bit just tells you the way its rotating its not rotating about the surface normal but rather like a dynamo would.
