How Efficient Can a Heat Engine Be Between 1200 K and 300 K?
  • Thread starter Thread starter science.girl
    Heat
The discussion revolves around a heat engine operating between temperatures of 1200 K and 300 K, tasked with lifting a 30 kg mass at a constant velocity of 4 m/s. Participants explore the power required for the engine, its maximum efficiency, and the heat transfer rates involved in the process.
  • Mixed
  • Participants discuss the calculation of power using the formula P = Fv and question the missing distance and time parameters for work determination. Some explore the implications of the first law of thermodynamics in relation to heat transfer and efficiency.
There is ongoing exploration of the relationship between work output, heat input, and efficiency. Some participants have provided calculations for power and efficiency, while others are questioning the application of thermodynamic principles and seeking alternative methods suitable for an algebra-based course.
Participants note that the course is non-calculus based, which influences the methods discussed for finding heat transfer rates. There is also mention of potential confusion arising from working on similar problems simultaneously.
science.girl
A heat engine is built to operate between temperatures of 1200 K and 300 K. It is used to lift a 30 kg mass at a constant velocity of 4 m/s.
a) Determine the power that the heat engine must supply to lift the mass.
b) Determine the maximum possible efficiency of the heat engine.
c) If the engine were to operate at the maximum possible efficiency, determine the following:
i. The rate at which the hot reservoir supplies heat to the engine.
ii. The rate at which heat is exhausted to the cold reservoir.
P = W/t
e = 1 - T1/T2
I figured out that (b) is 1 - (300/1200) = 75%.
For (a), there is no distance stated to figure out work (W = Fd), and there is no time to determine power (P = W/t). What am I missing?
Power= rate of doing work. = Fd/t = fv.
Oh! So, P = Fv = (30 kg)(9.8 m/s^2)(4 m/s) = 1176 J/s.
So, if the power supplied to lift the mass is 1176 J/s, and the maximum possible efficiency is 75%, then the rate heat is removed from the hot reservoir... Wouldn't that depend on the first law of thermodynamics?
[delta]U = Q + W
But how would you apply the equation exactly, and what would it signify?
[delta]U = Q + W
You do not need to apply the first law here. You just have to apply the efficiency. The work output is 1176 watts (J/s) at 75% efficiency (efficiency = work out/energy in) so the energy (heat flow) input must be...?
AM
AM
So, given the equation e = W/QH...
.75 = (1176W)/QH
QH = 1568 WAnd, for the rate at which heat is exhausted to the cold reservoir, does this also depend on an efficiency equation?
75% = 75/100 = 0.75
for rate at which heat is exhausted note that W = QH-QC. So dW/dt = dQH/dt - dQC/dt
djeitnstine said:
75% = 75/100 = 0.75
Hmm... Unfortunately, this is a non-calc based course, so would you know of another approach?
dW/dt = Power
dQh/dt = rate of energy output from the hot resevior
or perhaps delta Qh/ delta t which is average energy over a period of time
similar argument for Qc
djeitnstine said:
dW/dt = Power
Yes, but unfortunately, this is an algebra-based course. Is there another method for finding the rate at which heat is exhausted to the cold reservoir?
W = Qh-Qc
P = W/t = Qh/t - Qc/t
You know two of those terms. So find Qc/t
AM
Andrew Mason said:
W = Qh-Qc
AM
W = QH - QC
392 W = 980 W - QC/t
QC/t = 588 W
Correct?
science.girl said:
W = QH - QC
QC/t = 588 W
Correct?
I am not sure what you are doing here.
W/t = 1176 w
Qh/t = W/e = 1568 w
AM
W/t = 1176 w
Qh/t = W/e = 1568 w
AM
My apologies. I was working on two similar problems... that's why the values were different.
Thank you very much for your help! I appreciate it.
-Science.girl
  • · Replies 20 ·
