Fairly basic integral failing to become solved. O:-)
  • Thread starter Thread starter Saraphim
    Failing Integral
The discussion revolves around an integral involving the expression \((x^2+z^2)^{-3/2}\). Participants are exploring methods to approach this integral, which appears to be causing some confusion for the original poster.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster mentions attempts at integration by parts and substitution but feels uncertain about the correct approach. Some participants suggest considering trigonometric substitution, noting different forms that might be applicable based on the integrand.
Participants are actively engaging with the problem, offering suggestions for trigonometric substitutions. There is a sense of collaborative exploration, with some guidance provided on potential methods without reaching a consensus on the best approach yet.
The original poster expresses a desire for a nudge in the right direction, indicating a lack of confidence in their current approach. The discussion includes various suggestions for substitutions, but no definitive method has been agreed upon.
Saraphim
"Fairly" basic integral failing to become solved. O:-)
Hi,
I'm having trouble with an integral where I simply do not know where to start. I just need a little nudge in the right direction. I've tried integration by parts and by substitution, but I'm really just stumbling in the dark and should obviously choose something in a more well-informed manner. If I could just get a nudge in the right direction I think that I can solve it. :)
[tex]\int (x^2+z^2)^{-3/2}dx[/tex]
when you see a square root in your integrand, you will likely want to attempt trig substitution if there is no other obvious route.
There are 3 different trig substitutions possible based on the form under the root:
x = z * sin@
x = z * tan@
x = z * sec@
you should know which one to use based on that form.
tell us which is the correct substitution, and you should be able to solve it.
I'll have a go at that, thank you very much.
Try a trig substitution, tan u = x/z. Keep in mind that z^2 is a constant in this integral.
  • · Replies 22 ·
  • · Replies 105 ·
13K
  • · Replies 22 ·
