Cylinder Rotational Motion Question
The discussion focuses on the dynamics of a sphere rolling on a fixed rough circular cylinder, specifically deriving the relationship between angular velocity and the angle to the vertical. The formula derived is (w)^2 = [10g(1 - cos theta)] / [7(R+a)], where (w) represents angular velocity squared and g is the acceleration due to gravity. It is established that the sphere will lose contact with the cylinder at the angle theta = arccos(10/17), based on energy conservation principles and the condition of zero normal force.
  • Understanding of rotational motion and angular velocity
  • Familiarity with energy conservation principles in physics
  • Knowledge of the relationship between linear and angular velocity (v = rω)
  • Basic trigonometry, particularly the cosine function
  • Study the derivation of energy conservation equations in rotational dynamics
  • Learn about the conditions for rolling motion without slipping
  • Explore the implications of normal force in contact dynamics
  • Investigate the applications of angular motion in real-world scenarios
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of rotational motion and energy conservation in mechanical systems.
kongieieie
A sphere of radius a rests on top of a fixed rough circular cylinder of radius R which is lying with its principal axis horizontal. The sphere is disturbed and rolls, without any slipping, around the surface of the cylinder. Show from energy considerations that, if theta is the angle to the vertical made by the line joining the centre of the sphere directly to the axis of the cylinder, then
where (w)^2=angular velocity squared, g=acceleration due to gravity
Hence, show that the sphere will leave the surfacve of the cylinder at
theta = arccos (10/17)
Welcome to PF!
Hi kongieieie! Welcome to PF! :smile:
(have a theta: θ and an omega: ω and try using the X2 tag just above the Reply box :wink:)
kongieieie said:
Show from energy considerations …
Hence, show that the sphere will leave the surfacve of the cylinder …
Use KE + PE = constant, and v = rω, and remember the sphere will lose contact when the normal force is zero. :wink:
Show us how far you get, and where you're stuck, and then we'll know how to help! :smile:
Problem solved. Thanks for the hint. :)
  • · Replies 16 ·
  • · Replies 22 ·
