| Thread Closed |
Mass flow rate |
Share Thread | Thread Tools |
| Apr28-09, 11:24 AM | #1 |
Mass flow rate
A fluid of density 867 kg/m3 flows through a circular duct of diameter 40.60 mm with a mass flow rate of 14.63 kg/s. The fluid velocity in m/s is? 2. Relevant equations mass flow rate [kg/s] = density [kg/m3] x velocity [m/s] x area [m] 3. The attempt at a solution 14.63 = 867 x velocity [m/s] x pi(40.60/2000)^2 therefore: velocity = 13.03 m/s Though from my notes: Correct Answer: 1.190 m/s Am I doing something wrong or is the answer from my notes just wrong? Thanks in advance! |
| Apr28-09, 11:28 AM | #2 |
Recognitions:
I get the same answer as you.
14.63 kg/s / 867 kg/m^3 = 0.0168 m^3/s Area = 0.0013 m^2 So flow rate = 0.0168 m^3/s / 0.0013 m^2 = 13 m/s |
| Apr28-09, 11:40 AM | #3 |
Allright, thank you! Should be a mistake in the notes then.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Mass flow rate
| Mass flow rate | Advanced Physics Homework | 3 | ||
| Mass flow rate | General Physics | 8 | ||
| mass flow rate | Introductory Physics Homework | 5 | ||
| Question About Mass and Mass Flow Rate Relations | General Physics | 4 | ||
| Mass Flow Rate | Introductory Physics Homework | 6 | ||
