Why water freezes at low pressure?
  • Context: Undergrad
  • Thread starter Thread starter goku
    Pressure Water
Water freezes instantly at very low pressures, such as 15 mtorr, regardless of the temperature being above zero. This phenomenon occurs because evaporating water molecules carry energy away from the remaining liquid, leading to a cooling effect at the interface. To prevent freezing under low pressure, one can stir the water to maintain a higher temperature or add soluble substances like salt or antifreeze to lower the freezing point.
  • Understanding of phase changes in water
  • Knowledge of vapor pressure and its effects on freezing
  • Familiarity with colligative properties, such as freezing point depression
  • Basic principles of thermodynamics related to evaporation
  • Research the effects of low pressure on phase transitions in water
  • Learn about colligative properties and how they affect freezing points
  • Investigate the thermodynamic principles of evaporation and cooling
  • Explore the use of antifreeze solutions in various applications
Scientists, chemists, and engineers interested in thermodynamics, phase transitions, and applications involving low-pressure environments.
goku
water freezes instantly on very low pressure, irrespective the temp being well above zero. pls explain why? .what can be added to water so that it does not freeze at very low preesure (15mtorr)?
When evaporating water molecules detach from the condensed phase, they take energy with them. The remaining material cools down at the interface. So you could stir the water to maintain the temperature above freezing, or you could add something soluble (like salt) to depress the freezing temperature.
evaporation is a coolong process . just like when you put water on your finger and wave it around in the air it feels cooler , you could put anti-freeze in it.
  • · Replies 16 ·
9K
  • · Replies 160 ·
11K
  • · Replies 32 ·
13K
  • · Replies 16 ·
