Calculating Circulation of Vector G with Green's Theorem
The problem involves using Green's Theorem to calculate the circulation of the vector field \(\vec{G} = 3y\vec{i} + xy\vec{j}\) around a circle of radius 2 centered at the origin. The focus is on understanding the correct setup for the integral and the application of the theorem.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the correct form of the integrand based on the partial derivatives required by Green's Theorem. There is also a suggestion to consider polar coordinates for the integral.
The discussion is ongoing, with participants providing feedback on the original poster's attempt and exploring different interpretations of the integrand. Some guidance has been offered regarding the correct derivatives and coordinate systems, but no consensus has been reached yet.
There is a mention of the orientation of the curve being counterclockwise, which is relevant to the application of Green's Theorem. Participants are also reflecting on the implications of using Cartesian versus polar coordinates for the integration.
-EquinoX-
Use Green's Theorem to calculate the circulation of [tex]\vec{G}[/tex] around the curve, oriented counterclockwise. [tex]\vec{G} = 3y\vec{i} + xy\vec{j}[/tex] around the circle of radius 2 centered at the origin.
[tex]\int_{-2}^{2}\int_{-\sqrt(4-y^2)}^{\sqrt(4-y^2)} y-3 dx dy[/tex]
is this correct?
No, it isn't. Your integrand should be
[tex]\frac{\partial xy}{\partial y}- \frac{\partial 3y}{\partial x}[/tex]
What you have is
[tex]\frac{\partial xy}{\partial x}- \frac{\partial 3y}{\partial y}[/tex]
Also, although your limits of integration are correct for Cartesian coordinates, I think the integral would be easier in polar coordinates.
Hm.. the curve is oriented counterclockwise, so shouldn't it be ∂x(xy) - ∂y(3y), i.e. the z-component of ∇ x G?
Yes, sorry, my mind blew a fuse!
so it is correct isn't it?
