Tile a plane with three sided figures
  • Context: Undergrad
  • Thread starter Thread starter mee
    Plane
The discussion revolves around the possibility of tiling a plane using three-sided figures and explores the conditions under which various polygons can tile the plane, including both regular and irregular shapes. Participants examine the implications of convexity and regularity in the context of tiling with polygons of different side counts.
  • Some participants assert that one can tile a plane with three-sided, four-sided, and six-sided figures, questioning if other numbers of sides can also work.
  • Others propose that any even number of sides greater than two can tile a plane, citing an example of a modified octagon that can fit into itself.
  • A participant describes a construction involving pentagons that can form a seven-sided figure, suggesting that irregular shapes can also tile the plane, potentially allowing for all integers to be represented.
  • Another participant introduces the complexity of requiring convex shapes and discusses the angles of regular polygons, noting that only triangles, squares, and hexagons can tile the plane based on the divisors of 360.
  • A participant shares a link to a resource featuring tiling examples, referencing the work of Escher.
Participants express differing views on the types of polygons that can tile a plane, with some supporting the idea of irregular shapes and others focusing on regular polygons. The discussion remains unresolved regarding the complete set of polygons that can tile a plane.
The discussion includes assumptions about the regularity and convexity of shapes, as well as the mathematical conditions for tiling, which are not fully resolved. The implications of these conditions on the ability to tile with various polygons are explored but not concluded.
mee
I know one can tile a plane with three sided figures, four sided figures and six sided figures if each figure is identical. Are there any other numbers that would work?
Mathematics news on Phys.org
Actually, you can tile a plane with any even number of sides > 2, and 3 of course. I don't know if there are others.
I will show an eight sided figure that can be used to tile a plane, and the rest follows.
Imagine for now a regular octogon. Now, we take three consecutive sides of the octogon and flip them over to form a convex octogon which can fit into itself. This shape can be used to tile a plane. It follows that the same can be done for any greater even number of sides. This is just one example of a shape that can do it. There are infinitely many, of course.
Also there's...
_____________
|__ |__ |__ |__ Ignore the dots (only to make spacing work)
If that's impossible to comprehend, here, let me describe it...
Imagine a pentagon, with 3 neighboring sides at right angles, and the other 2 sides equal to each other. Now stick 2 such pentagons together (see figure for clue) and you have a 7 sided (double-house) figure. You can tile a floor with these.
In fact, the original pentagon (single-house) would itself work, as would, by extension, any number of such pentagons stuck to each other (n-house). All these figures have an odd number of sides.
Since there is no requirement for regularity in the problem, this, along with vertigo's demonstration, shows that tile-solutions exist for all integers.
I think this gets harder if you add the requirement that the shapes be convex.
Regarding regular polygons:
Consider that the angle of a regular n-polygon is [tex]180-\frac{360}{n}[/tex], and for a regular polygon, the angle needs to be a divisor of [tex]180[/tex] or [tex]360[/tex]. Since any divisor of [tex]180[/tex] is also a divisor of [tex]360[/tex], it's sufficient to deal with divisors of [tex]360[/tex].
Now, we know that the polygon will have 3 or more sides, so [tex]180-\frac{360}{n} \geq 60[/tex].
Simultaneously we have [tex]180-\frac{360}{n} < 180[/tex].
Now, we can list all divisors of 360:
[tex]360=2^3*3^2*5[/tex]
The divisors are
1 2 3 4 5 6 8 9 10 12 15 18 20 24 30 36 40 45 60 72 90 120 180 360
so the only possible divisors are :60,72,90, and 120.
We know that 60 (hexagon), 90 (square) and 120 (triangle) are represented, so the only one left to check is
72:
[tex]72=180-\frac{360}{n}[/tex]
[tex]\frac{360}{108}=n[/tex]
but [tex]\frac{360}{108}[/tex] is not an integer, so there is no suitable regular polygon.
Consequently, the ony regular polygons that tile the plane are triangles, squares, and hexagons.
check these tiles out : http://beloit.edu/~jungck/ ...Escher, I think.
  • · Replies 17 ·
