Solving Density Integral for Solid Cylinder
  • Thread starter Thread starter -EquinoX-
    Density Integral
The problem involves finding the density of a solid cylinder defined by the inequality y² + z² ≤ a² and 0 ≤ x ≤ b, where the density is proportional to the distance from the x-axis. The original poster seeks guidance on how to approach this integral problem.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the geometric interpretation of the cylinder and the relationship between the coordinates. Questions arise about the distance from the x-axis and how to express the density in terms of polar coordinates.
Participants are exploring different interpretations of the cylinder's orientation and the mathematical representation of density. Some guidance has been provided regarding the use of polar coordinates, but confusion remains about specific variable representations and the setup of the integral for mass calculation.
There is an ongoing discussion about the correct representation of the density function and the variables involved, particularly in relation to the integration process. The original poster is also working within the constraints of a specific cylinder radius and length.
-EquinoX-
The density of material at any point in a solid cylinder, y^2 + z^2 ≤ a^2, 0 ≤ x ≤ b is proportional to the distance of the point from the x-axis. Find the density. Use k as the proportionality constant.
Can someone guide me here? is x here a?
No x isn't a. That's the parametric representation of a cylinder whose axis coincides with the x-axis. Now from what is given you should be able to tell that the equation describes a circle on the y-z plane. What then is the equation of any point within that circle? That, and using pythagoras theorem should give you the answer.
how can I get the equation of any point within the circle?
Suppose the point is (x,y). What is distance from the centre to that point?
the point (x,y) you mean here are you referring that to a point in the circle or.. if I visualize this correctly the cylinder is not standing on it's base.. right?
Well it depends on what you mean by "base". The base of the cylinder is the y-z plane. So from the conventional orientation of x-y-z plane it's lying on its curved side.
The base should be centered at the origin, lying completely in the yz-plane.
Like this:
http://img22.imageshack.us/img22/5278/terip.jpg
ok.. so now I need to find the equation within the circle... I am really confused how this can be achievedf
If the coordinates of a point are (x, y, z), what is the distance of this point from the x-axis?
which part of the x-axis? the origin?
The shortest distance to the x-axis.
is the answer just k(y^2+z^2)?
You forgot the square root. The density is k√(y² + z²). You might also want to mention that the density is 0 for √(y² + z²) > a.
hmm.. yea I fogot the sqrt,, how can I express this in terms of r?
Are you going to use polar/cylindrical coordinates? Use the polar coordinates (r,theta) for the yz plane instead of the usual xy plane.
polar coordinates... how can I do that?
:confused:
I need to represent the density above in terms of r... not y and z
What is r? What does r mean?
I believe it's the radius
Well, you already know the radius is given by [tex]r=\sqrt{y^2 + z^2}[/tex]. So going from this to an answer in terms of r just requires to replace that latter expression with r.
I am asked to set up the integral to find the mass of such a cylinder with radius 6 and length 11.
f(x, r, θ) here is just the density? in terms of x, r and theta?
Yes I believe so. Now do a volume (triple) integration over the region.
well I am confused on how to represent the density in terms of f(x, r, θ)
Didn't you do so above?
one was in terms of x,y and one was in terms of r... but not f(x,r,theta).. I am mostly confused with the theta here
is it just something like this if the cylinder has a radius of 6 ad length 11:
[tex]\int_0^{11}\int_0^{2\pi} \int_0^6 kr^2 dr d\theta dz[/tex]
  • · Replies 41 ·
