Horizontal elastic collision between a ball and a block attached to a spring?
The discussion centers on a physics problem involving a perfectly elastic collision between a ball and a block attached to a spring. The block has a mass of 0.140 kg and a spring constant of 25 N/m, while the ball has a mass of 0.023 kg and is thrown at a speed of 5.2 m/s. Participants emphasize the use of conservation of momentum and conservation of kinetic energy to solve for the ball's speed after the collision. They clarify that the spring's compression can be ignored immediately after the collision, simplifying the problem to a standard elastic collision scenario.
  • Understanding of elastic collisions in physics
  • Knowledge of conservation of momentum and conservation of energy principles
  • Familiarity with spring mechanics, specifically Hooke's Law
  • Ability to solve algebraic equations involving multiple variables
  • Study the principles of conservation of momentum in elastic collisions
  • Learn how to apply conservation of kinetic energy in collision problems
  • Explore Hooke's Law and its applications in spring mechanics
  • Practice solving problems involving multiple unknowns in physics
Students studying physics, particularly those focusing on mechanics and elastic collisions, as well as educators looking for problem-solving strategies in collision scenarios.
offbeatjumi
The problem states: A 0.140 kg block on a frictionless table is firmly attached to one end of a spring with k = 25 N/m. The other end of the spring is anchored to the wall. A 0.023 kg ball is thrown horizontally toward the block with a speed of 5.2 m/s. What is the ball's speed immediately after the collision (if the collision is perfectly elastic)?
F(spring) = -k(change in s)
K(f) + U(f) = K(i) + U(i) ...---> K = (1/2)mv^2 ...U = (1/2)k(change s)^2
The one thing that prevents me from solving the problem is that I am unable to find the length of the compressed spring, and I also do not know how to use F = -k(change s) in this problem. I know that since this is perfectly ellastic, I should use conservation of momentum or conservation of energy, but I always come out with two unknown variables... the final velocity of the ball and usually, change in s. Any pointers? Thanks so much.
I could be wrong on this, but immediately after the collision the spring has barely moved at all. Therefore it is just an elastic collision between a ball and a block. Pretend the spring isn't there.
If there is a later question asking the amplitude of the oscillations, then you will know the initial velocity of the block from the previous elastic equation. And can solve for the amplitude.
Use conservation of momentum and conservation of kinetic energy. Stop the experiment before the spring starts to compress. You get two variables, but you also have two equations.
It's just algebra from there.
