Problem: properties of Fourier Transforms in Quantum Mechanics
The discussion focuses on deriving the property of the Fourier Transform of the wave function in Quantum Mechanics, specifically the equation F[ψ(cx)] = (1/|c|)ψ̄(p/c). The Fourier transform of ψ̄(p) is defined using the integral involving e^{−i(px/ħ)} and ψ(x), while the inverse transform is expressed with e^{i(px/ħ)}. The user attempted to change the integration variable to u = cx but struggled to achieve the desired result, indicating a misunderstanding of the Fourier Transform properties.
  • Understanding of Fourier Transforms in Quantum Mechanics
  • Familiarity with wave functions and their properties
  • Knowledge of integration techniques in physics
  • Basic concepts of quantum mechanics, particularly the role of ħ (reduced Planck's constant)
  • Study the properties of Fourier Transforms in Quantum Mechanics
  • Learn about the implications of scaling in Fourier Transforms
  • Explore the concept of wave function normalization
  • Investigate the role of the modulus in Fourier Transform equations
Students and researchers in quantum mechanics, physicists working with wave functions, and anyone interested in the mathematical foundations of Fourier Transforms in physics.
Sistine
I am trying to derive a property of the Fourier Transform of the wave function.
[tex]F[\psi(cx)]=\frac{1}{|c|}\overline{\psi}\left(\frac{p}{c}\right)[/tex]
The Fourier transform of [tex]\overline{\psi}(p)[/tex] is defined as
[tex]\overline{\psi}(p)=\frac{1}{\sqrt{2\pi\hbar}}\int_{-\infty}^{\infty}e^{-\frac{i}{\hbar}px}\psi(x)dx[/tex]
and the inverse Fourier transform
[tex]\psi(x)=\frac{1}{\sqrt{2\pi\hbar}}\int_{-\infty}^{\infty}e^{\frac{i}{\hbar}px}\overline{\psi}(p)dp[/tex]
I tried changing the integration variable
[tex]u=cx[/tex]
Then
[tex]\psi(u)=\frac{1}{\sqrt{2\pi\hbar}}\int_{-\infty}^{\infty}e^{\frac{i}{\hbar}pu}\overline{\psi}(p)dp[/tex]
But when I took the Fourier transform and substituted [tex]u=cx[/tex] I did not manage to get the desired result.
You're using the wrong Fourier Transform.
[tex]F[\psi(c x)]=\frac{1}{\sqrt{2 \pi \hbar}} \int_{-\infty}^\infty e^{-\frac{i}{h} p x} \psi(c x) dx[/tex]
Use the same substitution as you did previously and work it out from here.
Thanks, but why is there a modulus involved?
  • · Replies 0 ·
  • · Replies 30 ·
