Uncertainty in the standard deviation
The discussion focuses on calculating the mean and standard deviation (SD) of radioactive emissions measured by a detector over five intervals, yielding a mean of 15.4 and an SD of 3.5. The expected SD, calculated as the square root of the mean, is 3.9. The uncertainty in the SD is determined through error propagation, resulting in a value of 0.5. Participants debate the implications of using a small sample size and the accuracy of the calculated uncertainty in relation to larger datasets.
  • Understanding of basic statistics, including mean and standard deviation.
  • Familiarity with error propagation techniques in statistical analysis.
  • Knowledge of normal distribution and its properties.
  • Ability to perform calculations involving square roots and variances.
  • Study error propagation methods in detail, particularly in the context of standard deviation calculations.
  • Learn about the implications of sample size on statistical variance and uncertainty.
  • Explore the differences between normal and Poisson distributions in statistical analysis.
  • Investigate advanced statistical techniques for estimating uncertainty in small sample sizes.
Statisticians, data analysts, health physicists, and anyone involved in experimental data analysis and uncertainty quantification will benefit from this discussion.
Shukie
A health physicist is testing a new detector and places it near a weak radioactive sample. In five separate 10-second intervals, the detector counts the following numbers of radioactive emissions:
16, 21, 13, 12, 15.
a) Find the mean and standard deviation (SD) of these five numbers.
b) Compare the standard deviation with its expected value, the square root of the average number.
c) Naturally, the two numbers in part b) do not agree exactly, and we would like to have some way to assess their disagreement. This problem is, in fact, one of error propagation. We have measured the number v. The expected standard deviation in this number is just [tex]\sqrt{v}[/tex], a simple function of v. Thus, the uncertainty in the standard deviation can be found by error propagation. Show, in this way, that the uncertainty in the SD is 0.5. Do the numbers in part b) agree within this uncertainty?
a) Mean = 15.4
Standard deviation = 3.5
b) Expected SD = [tex]\sqrt{15.4} = 3.9[/tex]
c) I know that the following is true: [tex]{\sigma}(\sqrt{v})= {\sigma}_v*\frac{d(\sqrt{v})}{dv} = 0.5[/tex] where [tex]{\sigma}_v = \sqrt{v}[/tex]. How do I show by error propagation that the uncertainty in the SD is 0.5?
I don't see why this should be 1/2, neither from a scaling argument, nor from a simulation, nor from calculation.
* If we replace the 5 data points by a million then certainly our sample variance will be extremely close to the expected variance, and our uncertainty won't be 1/2. The question doesn't use the N=5 information.
* If we replace the 5 data points by 5 data points with an average of millions then clearly the sample variance will have a much larger variance. The 1/2 doesn't reflect that either.
I produced hundreds of sets of 5 numbers with a mean of 15.4 and a standard deviation of sqrt(15.4). I used a normal distribution because I didn't find a nice way to get Poisson-distributed numbers but that shouldn't matter. The standard deviations had a standard deviation of about 1.3, clearly not 1/2.The standard deviation is $$\sigma_{obs} = \sqrt{\frac{1}{N}\sum_i x_i^2 - \frac{1}{N^2}\left(\sum_i x_i\right)^2}$$
Looking at the first data point only:
$$\frac{d\sigma_{obs}}{dx_1} = \frac{1}{2 \sigma_{obs}} \left( \frac{1}{N} 2 x_1 - \frac{2}{N^2} \sum_i x_i\right) = \frac{1}{N \sigma_{obs}} ( x_i - \bar{x})$$
This intuitively makes sense: If a datapoint is below the average then raising it reduces the standard deviation, otherwise it increases it.
It's uncertainty is its own square root, so ##x_1##'s contribution to the overall uncertainty is ##\displaystyle \frac{1}{N \sigma_{obs}} | x_1 - \bar{x}| \sqrt{x_1}##. Adding the contributions in quadrature we get
$$(\Delta \sigma_{obs})^2 = \frac{1}{N^2 \sigma_{obs}^2} \sum_i (x_i-\bar{x})^2x_i$$
Not sure how to calculate the expectation value of that now. It seems to have the right scaling, it's larger for larger numbers and smaller for larger N.
Umm.. what is v?
I assume this means the uncertainty in the expected SD of the counts given only their mean.
  • · Replies 42 ·
