Capacitor Discharge: Calculating Time to 0.8μC
The problem involves a capacitor discharging through a resistor, specifically calculating the time it takes for the charge to decrease to a certain value. The subject area includes concepts from electrical circuits and capacitor behavior.
  • Exploratory, Assumption checking
  • Participants discuss the calculations involving the initial charge and the exponential decay formula for the capacitor discharge. There is a focus on verifying the calculations and questioning the accuracy of the provided answer in the practice test.
Some participants confirm the calculations appear correct, suggesting a possible error in the answer key. There is an ongoing exploration of the problem without a definitive resolution.
Participants are working under the assumption that the provided answer in the practice test may contain a typo, leading to uncertainty in the expected outcome.
Kalus
A 10 microfarad capacitor is initally charged to 15 volts. If the capacitor then discharges through a 12kohm resistor how long before the charge stored has falled to 0.8 x 10^-4 C?
Q=CV
Q= Q_0 x e ^(-t/RC)
Calculate initial charge using Q=CV
Q=CV
Q= 15x 10x10^-6
Qinital = 1.5x10^-4
Then using Q= Q_0 * e^(-t/RC)
Q= Q_0 x e ^(-t/RC)
0.8 x10^-4 = 1.5x10^-4 * e^(-t/12000*10x10^-6)
ln(0.8/1.5) = -t/12000*10x10^-6
ln(0.8/1.5)*12000*10x10^-6 = t
which when calculated comes out as 0.0754, or 75 ms.
However, the answer in the practise test is 120ms... anyone see what i am doing wrong?
Many thanks, Andy
Your calculations look fine to me, so I can only assume that there is a typo in either the answer key or the question sheet.
Thankyou for taking a look. I'd hoped that was the case and i wasn't going mad ;)
Andy
I punched those number real quick, and they are fine.
