Identifying the forces acting on masses in uniform circular motion.
The discussion focuses on calculating the tensions in a string connecting two masses (2kg and 1kg) in uniform circular motion at a rotation rate of 5 revolutions per second. The angular velocity is converted to 10π rad/sec. The correct approach to determining the tension in the string segments involves recognizing that the tension in the segment OP must equal the centripetal force acting on mass P plus the tension in segment PQ, leading to the equation: (Tension in OP) = m r ω² + (Tension in PQ). A free body diagram clarifies that the tensions act in opposite directions on mass P.
  • Understanding of uniform circular motion principles
  • Knowledge of centripetal force calculations
  • Familiarity with angular velocity conversions
  • Ability to draw and interpret free body diagrams
  • Study the derivation of centripetal force equations in circular motion
  • Learn about angular velocity and its applications in physics
  • Explore free body diagram techniques for analyzing forces
  • Investigate tension in strings and ropes in dynamic systems
Physics students, educators, and anyone interested in mechanics, particularly those studying forces in circular motion and tension analysis in systems involving multiple masses.
deancodemo
Two particles of masses 2kg and 1kg are attached to a light string at distances 0.5m and 1m respectively from one fixed end. Given that the string rotates in a horizontal plane at 5 revolutions/second, find the tensions in both portions of the string.
First I convert the angular velocity from rev/sec to rad/sec.
[tex]\omega = 5[/tex] rev/sec
[tex]\omega = 10\pi[/tex] rad/sec
Now, let the 2kg mass be P, the 1kg mass be Q and the fixed point be O. I understand that the tension in PQ < tension in OP. Actually, the tension in OP should equal the centripetal force acting on P plus the tension in PQ. Right?
I get confused when identifying the forces acting on P. By using R = ma:
[tex]R = ma[/tex]
(Tension in OP) + (Tension in PQ) [tex]= m r \omega^2[/tex]
(Tension in OP) = [tex]m r \omega^2 -[/tex] (Tension in PQ)
This is incorrect!
The only solution would be:
[tex]R = ma[/tex]
(Tension in OP) - (Tension in PQ) [tex]= m r \omega^2[/tex]
(Tension in OP) = [tex]m r \omega^2 +[/tex] (Tension in PQ)
Which makes sense, but this means that the tension forces acting on P in the different sections of string act in opposite directions. Is that right?
Draw a free body diagram of the forces acting on the mass at P. You will see both ropes on either side of the mass pulling in opposite directions. That is why your 2nd set of equations is correct.
  • · Replies 19 ·
