Change of temperature of ideal gas
The discussion centers on the temperature change of an ideal gas, specifically Argon (Ar) with a molar mass of 39.948 g/mol, under two different calculations of heat transfer. The user applied the internal energy formula, ΔU = (3/2)nRΔT, yielding a temperature change of 1.961 K, while the specific heat formula, Q = mcΔT, resulted in a temperature change of 1.177 K. The discrepancy arises from the incorrect use of specific heat capacity; the user should have utilized the specific heat at constant volume (c_v) instead of constant pressure (c_p) for accurate results.
  • Understanding of the ideal gas law (pV = nRT)
  • Familiarity with internal energy equations for ideal gases
  • Knowledge of specific heat capacities (c_p and c_v)
  • Basic thermodynamics concepts related to heat transfer
  • Study the differences between specific heat at constant pressure (c_p) and constant volume (c_v)
  • Learn how to apply the ideal gas law in various thermodynamic scenarios
  • Explore the derivation and application of the internal energy formula for ideal gases
  • Investigate the implications of heat transfer in real versus ideal gases
This discussion is beneficial for students studying thermodynamics, particularly those focusing on ideal gas behavior, as well as educators and professionals seeking to clarify concepts related to heat transfer and internal energy calculations.
hubber26
We have 1m3 of Ar gas M=39.948g/mol, pressure=101300Pa, temperature T=298K. We put the energy Q=1000J in that gas. Whats the temperature after we put 103J. (c=0.5203x103)
Im not interested in solution. I tried to solve it on two ways using formula for internal energy of ideal gas [tex]\Delta[/tex]U = [tex]\frac{3}{2}[/tex]nR[tex]\Delta[/tex]T and the formula Q = mc[tex]\Delta[/tex]T
However solutions are not the same, why?
pV=nRT => n = pV / RT = 40.89mol
m = Mn = 1633g = 1.633kg
thus [tex]\Delta[/tex]T = Q / [tex]\frac{3}{2}[/tex]nR = 1000 / (1.5*40.89*8.314) = 1.961°K
however
thus [tex]\Delta[/tex]T = Q / mc = 1000 / (1.633*0.5203*103) = 1.177°K
what is wrog please?
You took c to be c_p while you need c_v here.
right. Thanks very much!
  • · Replies 27 ·
