A Rocket's Distance from the center of the moon
  • Thread starter Thread starter gc33550
    Center Moon
The problem involves a projectile launched from the surface of the Moon, requiring the calculation of its maximum distance from the Moon's center based on its initial speed and the Moon's gravitational properties.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the application of energy conservation principles, questioning whether the initial speed is sufficient for escape. Various equations are proposed, and some participants express confusion over the calculations and the role of negative signs in gravitational potential energy.
The discussion includes attempts to clarify the equations used and the assumptions about kinetic and potential energy. Some participants provide calculations, while others seek explanations for the variables involved. There is a recognition of the challenges posed by the problem, but no consensus on a final solution has been reached.
Participants note the complexity of the problem and the potential for misunderstanding regarding the signs of gravitational potential energy. There is also mention of upcoming exams, indicating a shared context of academic pressure.
gc33550
The Moon has a mass of M= 7.0E22 kg and a radius of R=1.75E6 m. A projectile with
mass m=10 kg is shot straight up from the Moon’s surface with an initial speed of 500 m/s. What is the maximum distance from the center of the Moon that this projectile can reach?
E_initial=E_final
Kinetic_initial=Grav_potential
.5mv^2=GMm/r
Thinking through this I believe this is wrong, because essentially that is the equation for escape velocity. We don't know for sure that this rocket will escape... I am lost...
It is true for any velocity. Calculate r.
I didn't get the right answer...
Show your calculations.
r=(2GM)/v^2 is what i believe I worked it out to so
r=(2*6.7E-11*7E20)/500^2
r=3.752E5
According to the answer key it is supposed to be 1.84E6
So is there something I am missing I thought a simple energy conservation would cover it
Use the equation :
K+U = K_o+U_o
where K could be 1/2mv^2
and U = -GMm/r
tnutty said:
Use the equation :
K+U = K_o+U_o
and U = -GMm/r
I am assuming that there is no kinetic in my final state because the rocket doesn't have enough velocity to escape according to sqrt(2GM/r) so then:
(GMm/r_final)=.5mv^2+GMm/r_initial
r=GMm/(.5mv^2+(GMm/r_initial))
r= 6.7E-11*7E22*10/(.5*10*500^2+((6.7E-11*7E22*10)/1.75E6))
r=1.672e6
I still don't get the correct answer
here :
-GMm/ r =1/2m*v^2 - GMm/R_e
r = (1/R_e - v^2 / (2*G*M_e ) ^-1
r = 1.84E^6
Could I get a short explanation on that? I don't follow your variables
r=(-2*M_e*G*R_e)/(v^2*R_e-2*G*M_e)
r=(-2*7e22*6.7e-11*1.75e6)?(500^2*1.75e6-2*6.7e-11*7e22)
r=1.84e6
Good luck with your test today, I've been up all night studying for it, hope this helps!
Maybe my brain is physics fried haha But which Variables need to be negative and why? Is it both potentials? I thought the would have positive potential energy or is it the fact that it is in the negative direction? Oh boy I am going to fail haha
tnutty said:
Use the equation :
K+U = K_o+U_o
and U = -GMm/r
Use exactly what tnutty has written here for positive and negative values.
Dont worry about the final, I don't know if anyone is going to do well on it, its bad if I am aiming for a 50% on it...
The gravitational potential expression is
PE = -GM/r
So for your problem they would both carry a negative sign.
I also have my final today. Your's not with jones is it?
Jones? I go to Purdue
By the way I got it thanks guys... Those negative signs will get you every time haha
NO problem
  • · Replies 18 ·
