| Thread Closed |
Compressor vs Condenser - what's the difference? |
Share Thread |
| May8-09, 12:34 AM | #1 |
I read about refrigerators and often a fridge has two components:
1. compressor 2. condenser ![]() The compressor compresses the vapor - what does it actually do? does it increase the temperature of the vapor? The condenser condenses the vapor into liquid and then the liquid is expanded, resulting liquid and vapor in low pressure providing coolness If you compresses something, don't you just make it denser hence it has more pressure? How can you compress something without making it denser? Thank you |
| May8-09, 05:44 AM | #2 |
Mentor
Yes, the compressor compresses, resulting in higher temperature and density/pressure. You got that image from wikipedia - the next image down on that page gives you detail of what happens in each process.
| Thread Closed |
Similar discussions for: Compressor vs Condenser - what's the difference?
| burnt condenser | General Physics | 8 | ||
| Chemistry Question - Distillation - Why tilt the condenser? | Biology, Chemistry & Other Homework | 2 | ||
| heat exchanger capacity (condenser and evaporator) | Mechanical Engineering | 4 | ||
| Help! Finding molar flow rate of product out of a condenser | Engineering, Comp Sci, & Technology Homework | 3 | ||
| Need help with Spool and Condenser | General Physics | 1 | ||
