To find rocket's acceleration and velocity
The problem involves a weather rocket launched straight up, requiring the determination of its acceleration during the initial phase of flight and its velocity at a specific altitude after the motor stops. The context includes kinematics and the effects of gravity on motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss using kinematic equations to relate distance, velocity, and acceleration, while questioning the role of gravity in the calculations. There are attempts to set up equations involving two unknowns and explore how to eliminate one of them.
The discussion is ongoing, with participants providing hints and exploring different interpretations of the equations. Some participants express confusion about the relationships between the variables and the implications of gravity on the rocket's motion.
There is a noted lack of additional information in the problem statement, which participants are trying to navigate. The discussion includes considerations of how gravity affects the rocket's acceleration and velocity after the motor cutoff.
brunettegurl
A 1203.0 kg weather rocket is launched straight up. The rocket motor provides a constant acceleration for 11.2 s, then the motor stops. The rocket altitude 24.1 s after launch is 2023.0 m. You can ignore any effects of air resistance. What was the rocket's acceleration during the first 11.2 s? What is the rocket's velocity as it passes through a cloud 2023.0 m above the ground?
(a)d=Vit + 1/2 at^2...
(b) Vf= Vi + at...
(c) d= di + Vf (t) - 1/2 at^2
So I used the first equation to findthe distance the rocket traveled in the first 11.2 seconds and subtract that with altitude given...and know that the starting speed is 0m/s i tried to determine the speed using vfinal {throughout the first 2 eqns. i used a= -9.80 m/s^2}and then plugged it into the last equation to determine the acceleration..im gettin the wrong answer ..pls help
Well, first thing to think about: if an object is accelerating at -9.8 m/s^2, and its initial velocity is 0, is it moving down or up? Does that make sense for your problem?
-9.8 m/s^2 is the acceleration of gravity. But that's not the only acceleration involved - the rocket engine adds some acceleration of its own.
They want you to find 2 things. Vfinal and the initial a.
I'd look to develop 2 equations that are made of the 2 unknowns, and then solve.
For instance
Vcutoff = 11.2*a
and
Xcutoff = 1/2*a*(11.2)2
That yields ...
Vfinal2 = Vcutoff2 - 2*g*(2023 - Xcutoff)
Substituting into that then should yield your first equation in the 2 unknowns you need to find.
You just need another equation in the 2 unknowns then and you can solve.
so if i use the equation:: Vfinal2 = Vcutoff2 - 2*g*(2023 - Xcutoff) and sub into it the vcutoff and xcutoff i will still have the 2 unknowns in the same questions..this is a really stupid question but 2 eliminate one of the unknowns i wld have to use the other unknown correct?? but there's no additional info. given in the question to do this...
Sure there is.
Consider how the cutoff velocity is affected by gravity. How does that relate to Vfinal?
in the cutoff velocity the acceleration inclds gravity right?? and I am not really sure how it relates to vfinal...
The statement of the problem - constant acceleration to cutoff - means that gravity was taken into account in determining the acceleration to that point.
But after cutoff it is being slowed by gravity - there is no more propellant. So ...
Vfinal = Vcutoff - g*t
You can figure the time. You know g, so ...
and the time wld b the differnce between 11.2 s and 24.1 s where the altitude was measured ..correct??
That looks right.
ok so i did that and my hwk app. is telling me that the answer I am getting is wrong any more hints u can give me wld b really appreciated
It look's like a complicated calculation. Looks like you get a quadratic equation don't you? Are you sure you solved the quadratic correctly?
Maybe show what you get for your quadratic?
OK. I see the quadratic in a seems to cancel out the quadratic term., so it is a little simpler.
Maybe write out your equation with all the substitutions. There seems to be ample opportunity for arithmetic slip ups in this.
this is what i get as a quadratic equation:: 125.4a^2 + 1180.48a- 52800.002=0
and for my acceleration value i got 16.345m/s^2
As just mentioned when I worked it out, I lose the quadratic in a. It seems to cancel out.
Vf2 = (11.2*a)2 - 2*g*(2023 - 1/2*a*11.22)
Vf = 11.2*a - 12.9*g
(11.2*a - 12.9*g)2 = (11.2*a)2 - 2*g*(2023 - 1/2*a*11.22)
The (11.2*a)2 term on both sides cancels. So I don't see an a2 term.
i went over my calcs. and i realized i 4got 2 square my Vcutoff but i still didnt get the answer...the gravity will be negative thoughout the calcs right?
g is negative, but I accounted for that directly by putting its direction in the equation.
thank u so much...:))
  • · Replies 42 ·
