| Thread Closed |
Simulink help |
Share Thread | Thread Tools |
| May9-09, 12:15 AM | #1 |
Simulink help
Hi,
I have a project due that has to be done in Simulink. I am somewhat familiar with Simulink, but some things dont make sense to me. First off, What determines the time step between each iteration? eg. when you have a clock in the model, what determines the change in time from one iteration to the next? I remember working with a model once, and changing something in the model changed the sampling frequency for some reason, shich makes no sense to me. Thanks Raman |
| May9-09, 02:32 AM | #2 |
You can change the step size in the settings of the menu bar along with what kind of numeric solver it uses. i.e. ode45,ode23, etc.
| May10-09, 04:55 PM | #3 |
So if I have a input array which is to be used in the system, then I have to make sure the values in the input array are spaced the same time apart as the step size I specify in Simulink Options?
| May12-09, 03:54 AM | #4 |
Simulink help
How do I add an imput variable that is not a constant?
I have an array of values that I want the system to use, but I dont know how to get it to read the array one element at a time (each iteration I want it to take in one value from the array, and as it goes on it will read down the array). Thanks |
| May12-09, 09:10 AM | #5 |
| May12-09, 09:11 AM | #6 |
| May16-09, 04:59 AM | #7 |
thanks i was able to solve itl its jsut the "from workspace" block.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Simulink help
| Need help on Simulink | Programming & Comp Sci | 1 | ||
| SIMULINK - need help | Electrical Engineering | 0 | ||
| learning Simulink(Matlab) would help me build systems | Engineering Systems & Design | 1 | ||
| help on SIMULINK | General Engineering | 1 | ||
