How Do You Calculate the Resultant Force on a Mass on an Inclined Plane?
The discussion revolves around calculating the resultant force acting on a mass placed on an inclined plane. The scenario involves a smooth wooden board with specific dimensions and a mass of 100g, prompting participants to analyze the forces in play.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the need to find components of the weight acting parallel and perpendicular to the inclined board. There are attempts to relate gravitational potential energy to frictional force, with questions about the implications of a smooth surface. Some participants clarify that the only force acting on the mass is related to the gravitational force component down the incline.
The discussion is active, with participants offering hints and clarifications about the forces involved. There is recognition that the absence of friction simplifies the problem, and some participants are exploring how to calculate the angle based on the given dimensions. No explicit consensus has been reached, but guidance has been provided regarding the relevant forces.
Participants mention the context of preparing for exams and express concerns about understanding the topic. The problem setup includes specific measurements that may be relevant for calculating angles but does not provide complete information for a solution.
nigelhowie
The diagram shows a smooth wooden board 30cm long. One end is raised 15cm above the other. A 100g mass is placed on the board. The two forces acting on the 100 g mass are shown in the free-body force diagram.
what is the magnitude of the resultant force?
What do you think? Hint: Find components of the weight parallel and perpendicular to the board.
ok erm..
i was thinking
mgxsinθ = Frictional force x x
because since the object is not moving, gravitational potential energy is equals to frictional force?
please help me my edexcel exams are drawing really near.
thanks
btw, x= 30cm
When it says 'smooth' it means that there's no friction.
The only force on it as far as i can gather is the mgsin(theta).
So work out the force on it down the plane and from there you can work out acceleration and such, you only ever have to worry about friction if it says 'rough' or gives you a coefficient.
Edit: Also, out of interest is it the M1 exam you're taking? If so i'd check out this website
http://math.mdsalih.com/Data/index.php?d=Edexcel+Mathematics/M1
Many past papers - great practise with mark schemes.
Good luck.
nope I'm taking physics unit 1.
this topic is killing me.
thanks for the link anyway =)
ok. so, if there is no frictional force acting on the body,
so, basically, the only force acting on the object is mgxsin(theta)?
F = mgxsin(theta)
Correcto!
good luck :D
Hey, no it's not, sorry :P
no X there, the force isn't dependent on the distance travelled, sorry i didn't read it right :O
The force here would only be F = mg sin (theta).
I think the only reason why it gives you those measurements is so that you can work out the angle! Give it a go and see what you get.
oh yea thanks!
since
work done = force x distance moved in direction of force
so, X must not be calculated because if X is in, we're calculating work done.
thanks! =)
  • · Replies 25 ·
  • · Replies 56 ·
