Electrical field lines in conductive wire
The discussion focuses on the behavior of electric field lines within conductive wires, specifically cylindrical wires. When a voltage is applied, the electric field inside the wire is constant and parallel, with current density (J) being higher at the center. In the case of superconductors, which exhibit zero resistance, the electric field and current are uniform and parallel along the surface, with no field present deep inside. The concept of skin effect is also highlighted, where at high AC frequencies, current flows predominantly on the wire's surface.
  • Understanding of electric fields and current density (E = ρJ)
  • Knowledge of cylindrical wire geometry
  • Familiarity with superconductivity and its properties
  • Concept of skin effect in AC circuits
  • Study the principles of electric field distribution in conductive materials
  • Learn about the properties and applications of superconductors
  • Investigate the skin effect and its implications in high-frequency AC circuits
  • Explore the mathematical modeling of current density in cylindrical wires
Electrical engineers, physics students, and professionals working with conductive materials and superconductors will benefit from this discussion.
Mahbod|Druid
Hi
we connect a Voltage to heads of a conductive wire
how will be the field lines inside Wire ? (cylinder wire)
E = [tex]\rho[/tex] J
so ? :D
field lines are parrarell inside wire ?
in whole wire Electrical field is constant ?
(J must be more in center of wire)
what about Extreme Conductors ? ( i don't know the word in Eng , those with 0 Resistance)
If the current is constant it is a good approximation to assume, that the current and the electric field are the same everywhere and in parallel to the wire. Superconductors have currents only running on the surface, and there cannot be an electrical or magnetical field deep inside.
Seven-conductor wire (6 + 1 conductors) is a good compact design. For dc currents, the current is the same in every wire. The electric field lines are uniform and parallel to the wires, and are due to the wire resistance (div D = p). At high ac frequencies the currents flow in a thin layer (skin depth) on the outside of the wires.
  • · Replies 27 ·
  • · Replies 22 ·
