How Do You Simplify (i-3)^4 to a+bi Form?
  • Thread starter Thread starter Wasper
The discussion revolves around simplifying the expression (i-3) raised to the fourth power into the form a+bi, focusing on the manipulation of complex numbers.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore different methods for expanding (i-3)^4, with some breaking it down into smaller components and others suggesting alternative simplifications. There is also discussion about the properties of the imaginary unit 'i' and its powers.
Some guidance has been offered regarding the multiplication of complex numbers and the simplification of terms. Participants are actively engaging with the problem, sharing their reasoning and checking each other's work without reaching a definitive conclusion.
Participants note that the original poster is struggling with the simplification process and that there may be confusion regarding the steps involved in expanding the expression correctly.
Wasper
Express (i-3) to the 4th power in simplest a+bi form.
I know the answer , but cannot get my answer to be correct. Can someone help me solve this?
Thanks
Howdy Wasper,
Ok, I'd break it down like this;
(i-3)(i-3) = i^2-6i+9
Now, because the original is to the fourth power you would have two groups like this;
(i^2-6i+9)(i^2-6i+9)
Multiply all the above out properly and after combining like terms you have;
= i^4-12i^3+54i^2-108i+81
Now, using what you know about 'i' raised to a power (how it repeats, and so forth) you will be able to transform some i's into numbers. The numbers will then combine and reduce to;
28-96i
Well, at least I think that's about right, haha, because I think I goofed on one of the signs but I'm too lazy to go back over it again and check my work. I think you can take it from here. It's actually quite a fun thing to do when you start getting the hang of it and have your mind free to concentrate.
[edit]
Ooops, I just noticed this was homework help :frown:
Anyway, since I've gone this far already and because I don't know your level of understanding I'll rehash what I did above a little;
(i-3)^4 = (i-3)(i-3)(i-3)(i-3)
I broke it down into two groups of;
[(i-3)(i-3)]x[(i-3)(i-3)] = [i^2-6i+9]x[i^2-6i+9]
Do you follow?
You could have just kept grunting them out by only multiplying the quantity (i-3) over and over, but the way I did it seemed more of a shortcut (but it is probably easier to confuse yourself doing it that way too). Lastly, the imaginary part might seem confusing at first but is actually rather easy if you beat it into your brain that because i = squareroot of negative one you get the following repeating patern;
i^1 = sqrt -1
i^2 = (sqrt -1)(sqrt -1) = -1
i^3 = (-1)(sqrt -1) = (-1)(i) = -i
i^4 = (-1)(-1) = 1
Looking at the results from above you can see that i^5 is just going to be (sqrt -1)(1) = sqrt -1 = i^1, so i^5 ends up being i^1 (pattern repeats all over again). Do you suppose the odds are high that i^6 will end up being equivalent to i^2 ?? Yes, because it would be the equivalent of (i^2)(i^4) = (-1)(1) = -1 = i^2.
On i^4, an easy way to determine the answer is is by recalling what i^2 was equal to). You could grunt it out, however, by using the value of i^3 multiplied by sqrt -1 and getting in lots of good practice manipulating things;
= (-i)(sqrt -1)
= (-i)(i)
= -i^2
= (-i)(-i)
= (-sqrt -1)(-sqrt -1)
= -[(sqrt -1)(sqrt -1)]
= -[-1]
= 1
There, I hope that makes up for my having blabbed to much.
Just to point out that you don't really NEED to multiply
(i^2- 6i+ 9)(i^2- 6i+ 9) in that form.
i^2- 6i+ 9 is, of course, -1- 6i+ 9= 8- 6i so it is simpler
to multiply (8- 6i)(8- 6i)= 64- 2(8)(6)i+ 36i^2= 64- 96i- 36
= 28- 96i just as BoulderHead said.
my mistake was trying to do the (i-3) square it to the 4th power all at the same time. I think I got it now.. thanks for the help guys.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 88 ·
