Metalic apparatus to receive the discharge of a lightning near houses
  • Context: High School
  • Thread starter Thread starter DaTario
    Discharge Lightning
The discussion centers around the purpose and functioning of metallic apparatus, known as lightning conductors, designed to receive lightning discharges near buildings. Participants explore various theories regarding their effectiveness and the underlying physical principles, including their shape and electrical behavior.
  • Some participants propose that lightning conductors serve as a safer channel for lightning strikes, directing the electrical current harmlessly to the ground.
  • Others argue that the sharp edges of the apparatus may act as a mechanism to discharge electrical charge into the atmosphere, potentially reducing the likelihood of a lightning strike on the building.
  • A participant questions the survival of the wire during a direct lightning hit, expressing uncertainty about its resilience.
  • Another participant mentions a discredited theory suggesting that lightning conductors might actually increase the chance of a strike by allowing induced ground charge to create a higher potential closer to the clouds.
  • There is a request for references to support the claim that lightning conductors may increase strike probability.
Participants express differing views on the effectiveness and mechanisms of lightning conductors, with no consensus reached on their role in preventing or attracting lightning strikes.
Limitations include the lack of empirical evidence for the claims made regarding the mechanisms of lightning conductors and the varying interpretations of their function.
DaTario
Hi All,
I would like to know what is the main reason to build those metalic apparatus to receive the discharge of a lightning near houses. I am concerned with its shape and its physical explanation.
Any help will be welcome,
Thank you all
Best wishes
DaTario
They are called lightning conductor and are to protect the building if it is struck by lightning.
They are simply metal wires going from above the building to ground. The idea is that the lightning hits the point rather than the building and the electrical current flows through the metal wire harmlessly to the ground instead of through the building.
Because the building has a high electrical resistance the lightning current flowing through it would produce a lot of heat energy and almost certainly start a fire.
I'm not sure if the wire would survive a direct hit.
The pointed rods (connected to ground) release a stream of electrons into the air--trying to keep the atmosphere around the building from building up a charge that would 'attract' the lightning.
If course, I don't know why the lightning doesn't see the points as 'ground' (which would be many meters above the real ground) and strike it anyway.
Neil
Hi,
You two gave the taste of my problem. There are two main reasonings and each one of you has defended one of them.
The first is that the apparatus serve as a preferential and safer conductor channel for the electricity.
The second says that the sharp edge of this apparatus serve as a leaking mechanism, which is always throwing earth-charge into the air (atmosphere). This "may" lower the earth-charge density in the neigborhood of the building, lowering therefore the probability of hapening a discharge (lightning) in the very building (or its point-apparatus).
I again welcome contributions.
Thank you
DaTario
The theory that lightning conductors prevent strikes by discharging the building is discredited, in fact lightning conductors may slightly increase the chance of a strike because they allow the induced ground charge to create a potential at a higher point - nearer the cloud.
Hi mgb,
Is there any reference to this point of view? Any site?
Do you believe that these two factor act together, yielding what you called "slightly increase" ?
Best wishes
DaTario
mgb_phys said:
...may slightly increase the chance of a strike because they allow the induced ground charge to create a potential at a higher point - nearer the cloud.
This is the thought that made me add the ending statement to my post.
Neil
  • · Replies 57 ·
  • · Replies 24 ·
  • · Replies 18 ·
