Different Statements of Morera's Theorem
  • Context: Graduate
  • Thread starter Thread starter variety
    Theorem
Morera's Theorem in Complex Analysis establishes that a continuous function \( f \) defined on a region \( G \) is analytic if the integral \( \int_T f = 0 \) for every triangular path \( T \) in \( G \). The discussion clarifies that this theorem can be extended to state that if \( \int_{\Gamma} f = 0 \) for every simple closed curve \( \Gamma \) in \( G \), then \( f \) is also analytic on \( G \). The transition from the first statement to the second relies on the fact that triangular paths can approximate any simple closed curve through finer subdivisions, ultimately leading to the conclusion that the integral over the closed curve will also be zero.
  • Understanding of Morera's Theorem in Complex Analysis
  • Familiarity with continuous functions in the context of complex variables
  • Basic knowledge of integration over paths in complex analysis
  • Concept of oriented manifolds and their significance in integration
  • Study the implications of Morera's Theorem in complex analysis
  • Learn about oriented manifolds and their role in path integration
  • Explore the relationship between triangular paths and simple closed curves
  • Investigate additional theorems related to analytic functions in complex analysis
Students and professionals in mathematics, particularly those studying complex analysis, as well as educators seeking to clarify the implications of Morera's Theorem and its applications in analytic function theory.
variety
In my Complex Analysis text, Morera's theorem states that a continious function whose domain is a region G is analytic if [tex]\int_T f=0[/tex] for every triangular path T in G. However, other versions of the theorem state that the integral must be zero for any simple closed curve in G. Can someone explain how one can go from the first statement to the second one? It doesn't have to be a full proof; just a heuristic argument. I'm just curious. It's probably something to do with the fact that any curve can be segmented into straight line segments or something, but I haven't taken any topology courses so I don't even really know what I'm taking about.
yeah, you've got the idea. these triangular sections will become a more and more fine approximation of the enclosed region, so the first implies the second in the limit. but you really need an oriented manifold for this loop to be in, so that an orientated clockwise ABC triangle will attach to an oriented clockwise DCB triangle to make an oriented ABDC quadralateral. so the idea is to fix an origin and cut up the loop into same-oriented triangles which include the origin as a vertex, and all the interior segments will cancel out, leaving just the loop to integrate.
Let f be a continuous complex-valued function on the open set G.
Thm M1: If [tex]\int_T f=0[/tex] for every triangular path in G, then f is analytic on G.
Thm M2: If [tex]\int_{\Gamma} f=0[/tex] for every simple closed path [tex]\Gamma[/tex] in G, then f is analytic on G.
variety, you asked how to go from Thm M1 to Thm M2. But if you know Thm M1 is true, isn't Thm M2 a trivial corollary? (If the integral is zero for every simple closed path, then the integral is certainly 0 for every triangular path.)
  • · Replies 21 ·
  • · Replies 35 ·
