Solving Nuclear Physics Revision Questions: Li and Be
The discussion revolves around identifying the stable nucleus between lithium (Li) and beryllium (Be) based on their atomic masses and determining the mode(s) of decay for the unstable nucleus. The context is nuclear physics, specifically focusing on concepts of nuclear stability and decay processes.
  • The original poster attempts to understand how to identify the unstable nucleus without prior knowledge of the answer, noting that both nuclei are isobars with the same mass number. Some participants discuss the relationship between mass and stability, while others reference literature on nuclear stability ratios.
The discussion is ongoing, with participants exploring different aspects of nuclear stability and decay. Some guidance has been offered regarding the stability of light elements and the implications of nucleon ratios, but no consensus has been reached on the specific identification of the unstable nucleus.
The original poster expresses uncertainty about identifying the unstable nucleus and seeks clarification on the relevance of mass differences. There is also a mention of a textbook that may provide additional context on nuclear stability.
peterjaybee
Hello, I am having issues with some nuclear physics revision questions
The following atomic masses have been determined (in Atomic mass units, u) (A = atomic mass number, Z = proton number)
Li(A=7,Z=3) - 7.0182 u
Be(A=7,Z=4) - 7.0192 u
Indicate the stable nucleus and determine its mode(s) of decay.
Ok I have approached this knowing the answer, but not understanding it. The Be nucleus is unstable and decays into the Li, most likely by electron capture.
My problem is I do not understant how to identify the unstable nucleus without reading the answer. The only thing I have noticed which may or may not be relevant is that both nuclei have the same mass number, A, making them isobars.
Can someone please explain how to identify the unstable nucleus?
Many thanks,
Peter
The only thing I notice is that the beryllium atom has a slightly greater mass (by 0.001 u) than the lithium atom. When particles decay they lose mass, they don't gain it.
Modern Physics by Tipler/Llewellyn (4th ed.) has a good overview of nuclear physics. On pp. 516-518 they have a good discussion of nuclear stability.
The short of it is this: for light elements (like Li and Be), the most stable ratio of nucleons is roughly 1:1. Both neutrons and protons are fermions, so the exclusion principle makes it very energetically unfavorable to have a nucleus composed of purely protons or purely neutrons, hence the stability when they're about half and half. With heavier elements, Coulombic interactions among the protons becomes very significant, such that the population of neutrons becomes noticeably larger than that of protons. For example, uranium-238 [the most stable isotope of uranium] has 92 protons and 146 neutrons.
So in the case of your problem, we have an odd number of nucleons, so we can pick either 3 neutrons/4 protons (Be) or 4 neutrons/3 protons (Li). To minimize Coulombic repulsion, pick the one with fewer protons as the stable nucleus. As for which reaction it undergoes, there are only four common ones (alpha, beta+, beta-, and electron capture). Pick the one that gives you the correct change in A and Z, and if there is more than one that could do so, use conservation laws to figure out if one is more favorable than the other.
Thanks to both of you, I shall go in search of that book in the morning.
  • · Replies 24 ·
  • · Replies 23 ·
  • · Replies 20 ·
