Negative Energy Solutions to Photon Wavefunction
The discussion revolves around the existence of negative energy solutions in the context of the photon's electric field as described by Maxwell's equations. Participants explore theoretical implications, potential applications, and the treatment of these solutions in quantum electrodynamics (QED).
  • Some participants propose that the standard differential wave equation from Maxwell's relations leads to both positive and negative energy solutions for a photon's electric field.
  • Others question whether negative energy solutions actually exist, suggesting that the energy of an electric field is proportional to E^2, which implies only positive energy solutions are possible.
  • One participant speculates that negative energy solutions might be relevant when considering excitations of the vacuum and questions whether QED theorists discard these solutions.
  • There is a suggestion that it might be possible to create a zero energy superposition state using positive and negative energy photons, raising questions about the nature of such a state.
  • Concerns are raised about how the electric and magnetic fields transform under energy inversion, indicating that the superposition of positive and negative energy photons may not be straightforward.
  • Historical references are made to Dirac's negative energy solutions for electrons and the concept of antiparticles, with some participants expressing uncertainty about the existence of negative energy photons.
Participants express differing views on the existence and implications of negative energy solutions, with no consensus reached on whether they are valid or relevant in the context of Maxwell's equations and QED.
Limitations include the dependence on interpretations of Maxwell's equations and the unresolved status of negative energy solutions in the broader context of quantum field theory.
RoKo
Hello:
My question is simple: Does not the standard differential wave equation from Maxwell's relations lead to both positive and negative energy solutions for a photon's E field? If so, then why do we always throw away the negative energy solutions? Is this just custom? I suspect it is. But when considering excitations of the vacuum, it appears to me that the negative energy solutions for the photon would be important. Are they thrown away by QED theorists?
Could it be possible to create a zero energy superposition state with positive energy photons superposed to negative energy photons? And would that state not take zero energy to make, by definition? What would the wave function of such a state look like then?
Maybe QED theorists treat negative energy photons as positive energy photons moving backwards in time.
And when dealing with negative energy photons, is there not the apparent necessity of understanding how the E and B fields transform under energy inversion? So, perhaps the E and B fields of positive and negative photons don't superpose in such a simple manner.
I believe this all relates to an important real-world physics problem, and I believe I know some of the answers I am seeking, but because I am an experimentalist, I am seeking advice from a "higher authority."
Thanks for your help.
RoKo
Science news on Phys.org
RoKo said:
Hello:
RoKo
Does it gives a negative solution?
Long time ago I learned that the Dirac equation for spin half electron gives negative energy solution.
Yes, I believe that if you carefully work through the standard differential equation for the photon, you will see that there are negative energy solutions.
Dirac did indeed get negative mass solutions for the electron and that led him eventually to come up with the idea for the positron. So, antiparticles have their basis with the negative mass electron.
But I don't believe anyone has ever searched for either negative energy photons or negative mass electrons. Do they exist? I believe maybe they do.
RoKo
RoKo said:
... Dirac did indeed get negative mass solutions for the electron and that led him eventually to come up with the idea for the positron. So, antiparticles have their basis with the negative mass electron...
RoKo,
Does it means that Dirac’s prediction don’t derived from the negative mass solutions, because positron has opposite charge not a mass.
This is really a physics question, not mathematics, so I am moving it.
RoKo said:
Hello:
RoKo
Give me a solution in which E field has a negative energy.
I mean classical, Maxwellian. No QED.
RoKo said:
Hello:
Does not; the energy of an Electric field goes as E^2 (where E is the electric field), therefore there are only positive energy solutions...at least with Maxwell's eqns.
Creator
  • · Replies 21 ·
  • · Replies 26 ·
