Subspace & Dimension of V in P2 - Closure and Dimension Analysis
The discussion revolves around determining whether a specific collection of polynomials, defined by the condition a = b + c, forms a subspace of the vector space P2. Participants are exploring the implications of this condition on the dimension of the subspace V.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss closure under addition and scalar multiplication to establish V as a subspace. There are attempts to identify a basis for V and to determine its dimension, with questions about the linear independence and spanning of proposed basis vectors.
Some participants have offered guidance on proving linear independence and spanning properties of the proposed basis. There is an ongoing examination of the definitions and relationships between the coefficients of the polynomials, with multiple interpretations being explored regarding the structure of the subspace.
Participants are navigating constraints related to the definitions of the polynomials and the conditions imposed on the coefficients. There is a focus on ensuring that the proposed basis meets the requirements for spanning and independence without assuming conclusions prematurely.
bcjochim07
Is the collection a subspace of the given vector space? If so what is the dimension?
V={ax^2+bx+c: a=b+c} in P2
The first part of the question is pretty straightforward. I just verified closure under addition and scalar multiplication to show that V is indeed a subspace of P2. But I am confused about the second part. I know that the dimension of P2 is 3, so dimV must be < or = 3. I want to say three, but that would mean that V=P2, and I'm not sure that that's true. Any ideas?
You have the condition that a = b + c, so a is constrained. b and c completely specify a. Can you show the dimension explicitly from this?
Hmmm...ok. I think that a basis for V would be {x^2+x, x^2+1}, and therefore the dimension is 2.
Okay, why do you think that is a basis? Are x^2+ x and x^2+ 1 independent? Do they span V?
Well, {x^2+x, x^2+1} is linearly independent, and I think they span V since it contains all of the different polynomial terms as well as satisfying the restrictions placed on the coefficients. Is that not right?
Thinking it is not the same as having a proof for it. Forget polynomials - it's just 3-tuples
(a,b,c)
such that a=b+c. Is (1,1,0) and (0,1,1) a basis? I.e. are the linearly independent, and do they span? Even more explicitly, if x(1,1,0)+y(0,1,1)=(0,0,0) what does that say about x and y? And given (a,b,c) in the subspace, can you write it as r(1,1,0)+s(0,1,1) for a suitable r and s?
Of course, you can use x2, etc. if you want to!:-p
To show they are independent, look at the equation [itex]\alpha(x^2+ x)+ \beta(x^2+ 1)= 0[/itex] (= 0 for all x). What must [itex]\alpha[/itex] and [itex]b[/itex] equal?
Since V consists of all polynomials of the form [itex]ax^2+ bx+ c[/itex] with a= b+c or [itex](b+c)x^2+ bx+ c[/itex], to show that these span V, look at the equation [itex]\alpha(x^2+ x)+ \beta(x^2+ 1)= (b+c)x^2+ bc+ d[/itex]. Can that be solved for [itex]\alpha[/itex] and [itex]\beta[/itex] for all b and c?
Yes, I've got the linear independence part, alpha and beta equal 0. So point #1 for a basis is satisfied by B= {x^2+x, x^2+1}
Ok, so for any arbitrary polynomial in V, (b+c)x^2+bx+c, exists in the span of the basis vectors.
so c1(x^2+x) + c2(x^2+1) = (b+c)x^2+bx+c
=c1x^2 +c1x + c2x^2 + c2 = (b+c)x^2 + bx + c
so the resulting system of equations is:
c1+c2 = b + c
c1=b
c2=c and this system is consistent.
So I have shown that my proposed B is indeed a basis for V and that V is a 2 dimensional subspace of P2.
You've just assumed the answer - you can't write (b+c)x^2+bx+c as an arbitrary vector in V when you're trying to show that such a decomposition exists.
c1+c2 = b + c
c1=b
That's the wrong way- you have shown that (b+c)x^2+ bx+ c in of the form ax^2+ bx+c with a= b+ c which was obvious from the definition of the subset.
I said before
HallsofIvy said:
Look at the equation [itex]\alpha(x^2+ x)+ \beta(x^2+ 1)= (b+c)x^2+ bc+ d[/itex]. Can that be solved for [itex]\alpha[/itex] and [itex]\beta[/itex] for all b and c?
Do that!
