Importance of skin depth in radio communications
The discussion centers around the concept of skin depth and its significance in radio communications, particularly regarding how it affects signal transmission and reception.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants explore the relationship between radio transmission frequencies and skin depth, questioning whether lower frequencies are preferable for reducing absorption by obstructions. Others suggest that various techniques are used across the RF spectrum regardless of skin depth, leading to inquiries about the implications for circuit components and aerial design.
The conversation is ongoing, with participants sharing their thoughts and questioning each other's assumptions. Some guidance has been offered regarding the use of different techniques for various frequencies, but there is no clear consensus on the importance of skin depth in relation to aerials and signal reception.
Participants are navigating the complexities of skin depth in relation to radio frequencies and aerial design, with some uncertainty about the fundamental principles involved. There is a lack of explicit definitions or established parameters for the discussion.
benben26
'Briefly explain the importance of skin depth in the context of radio communications.'
A guess would be that, the frequencies of the radio transmissions should be kept small so that the signal has a large skin depth and is not absorbed by obstructions easily. I'm not too sure though. Is this right?
Not really, we utilize frequencies on all the spectrum regardless of the skin depth, we just adapt different techniques to deal with different parts of the RF spectrum.
As you go higher in frequency the signal tends to travel more on the surface.
So can you expect that some component of a circuit can depend on its the surface area?
I don't really understand your question...the aerial?
So if it is the ariel, what is the importance of skin depth?
So we want a very small skin depth so the aerial receives the EM wave easilly and converts this into a current?
9K
15K
  • · Replies 39 ·
